Question about Bowflex TreadClimber TC5
Clunking sound with TC5
When tradles come down there is a clunking sound. What to do to fix it?
Walking Belt Fraying
The bow flex tc5 is an overpriced piece of equipment. The build quality is not great. There are ongoing documented problems with the belts fraying on this model. You can always order a new belt or adjust the side (loosening or tightening) your primary foot stepping side, but I would call bow flex and demand a new belt or replacement. You can mention there is a "risk of fall" due to poor workmanship. This will get their attention and you may even get a new treadmill or at least free belt. Call Bow flex customer service at 1-800-436-6549.
Mar 18, 2014 | Bowflex TreadClimber TC5
How to adjust belts on TC5
This is not a easy job. Too many steps to tell.
Nov 30, 2013 | Bowflex TreadClimber TC5
Belt off center on tc5
see the video and proceed according. God bless you
Mar 29, 2013 | Bowflex TreadClimber TC5
LUBEthe deck belt and rollers bearing too. see the video
Test the motor bearing +dirve belt too
Jan 22, 2013 | Bowflex TreadClimber TC5
The compressor makes a big clunk clunk sound when it shuts off
The compressor motor mount is broken and that allows the compressor to flop around and clunk when shutting down.
That also allows it to twist and turn as it starts...
this will have to be fixed before the refrigerant piping breaks...
heatman101
Oct 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My car makes a clunk sound sometimes when I drive.
without having vehicle up on a four poster and putting my head underneath ?? as for the rattle ?? this could be pinking caused by low octane fuel ,95 unleaded is what it should have
Apr 05, 2010 | 2006 Pontiac G6
Power windows won't work. they are not rolling up or down.
It can only be one of a few things. First if it is the switch it won't make any sound at all when you press the button. If you can hear a sound, then the motor is running. If it has a 'clunk-clunk-clunk' sound to it then the gear plugs in the window motor need replacing which always happens around 10 years old. If you hear the motor running without the 'clunk-clunk-clunk' then the regulator cable has jumped track and the regulator will need replacing.
Nov 13, 2009 | 1996 Cadillac DeVille
Range Rover - Power Window - Clunk
You more than likely have a regulator (the piece holding the glass that scissors up and down) that is in a bind. Need to inspect it prior to ordering parts but I bet it is the regulator track bushing that has come apart and is binding.
Mar 28, 2009 | 1992 Land Rover Range Rover
HP 2410 printer won't boot up, just makes a clunking sound.
Someone just had a similar problem.
Unplug your printer for a few hours.
Plug it back in and the problem clear.
Jan 29, 2009 | HP Photosmart 2410 All-In-One InkJet...
Bowflex TreadClimber TC5 Logo
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
