Question about GE Microwave Ovens
DVM1850Dm2BB need wattage
What is the wattage for ER-4010
Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
Sep 21, 2017 | Goldstar Microwave Ovens
What is the wattage
There are 2 different wattage's on a microwave oven.
1 The wattage a microwave oven uses from your wallsocket that is in a range from 1500 watt to 2500 watt. you can read this on the typeshield on the back of the oven.
2 The wattage the oven put in you food. ( that is also the wattage that a foodpackage or recepy mentions. it is normal in the range from 600 to 1200 watt. you have too lookup this in the manual or manufacturers website.
Mar 03, 2015 | Microwave Ovens
Wattage on JCPenney 863-5973-60
Multiply the Voltage times the current to get wattage. The information plate on the unit will give you both numbers. In either case the MAX it would use would on a 15amp 120 Volt circuit would be 1800 watts. If its on a 20 amps circuit it would be 2400 watts. Unless its on a 220V circuit it would be one or the other. If its installed properly it should be on its own circuit breaker, see what size of circuit breaker its on and use the appropriate value. it could be less but it will not be more than these values.
Dec 23, 2014 | In Microwave Ovens
I need to know the wattage of my magic chef oven model 6898VV
Hi Nadia,
There's little to be found on the internet for this model oven now. There should be a name plate / manufacturer's sticker either inside the door - on the jamb; or on the rear near the power cord. If you see a rating given as "120VAC / 1200W" this would indicate INPUT wattage, which would be higher than the amount used for cooking. A typical 1200W rated microwave might have 800 - 1000 Watts of cooking power. If there are 2 ratings for wattage like 120V / 1200W / 850W; the 850 Watts is the amount of cooking power. The cooking power - or wattage - is always lower than the total wattage. If you see a rating somewhere that indicates 900W cooking power, then that would be the cooking power of the oven.
If you're not satisfied or unsure about the information you're finding on the oven - or it is missing - you might want to contact Magic Chef Customer Service Department at (888) 775-0202. They should be able to help you - or pint you in the right direction.
Apr 07, 2014 | Magic Microwave Ovens
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
Need wattage for sunbeam SBM7700W SN#401TA12770
read the tag on the back or its stamped on the rear cover, take your input voltage i.e. 120volts times the current draw i.e. 20 amps and this will give you the unit wattage
Sep 09, 2009 | Microwave Ovens
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Wattage for MW8985WD microwave
I still have a orginal lable on my microwave, it is a 800 watt oven.
Jan 13, 2009 | Emerson MW8985W Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
