Question about VistaQuest Fs501-S1 Mini Film Scanner Vistaquest
My Vistaquest FS 501 film & slide scanner has stopped working
The red light goes on wheb attached to computer but nothing on the screen. Is there an internal battery and how do you get to it? it has been working but not now
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: purchased Vistaquest FS-503 converter.
take it back for exchange or a refund. A capacitor in the circuit is at fault not distributing the needed power to operate this camera
Posted on Jun 26, 2011
Scanner doesn't recognise their is a slide loaded in the slide holder
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Mar 22, 2014 | Nikon CoolScan V ED Film Scanner
Film 2 SD Shuts Down
I have a question to ask you( you idiot) not a solution . Paul
Nov 05, 2011 | ION Audio Film2SD Film Scanner
Purchased Vistaquest FS-503 converter. Used two days. Screen doesn't light up and closing cover doesn't turn off the power (light continues showing through the slot for slide holder). Any easy...
Jun 26, 2011 | VistaQuest Cameras
I need software for iconvert software for a scanner I bought at brookstone. It did not come with a cd. Please help me
I had the same problem I found that the missing CD is downloadable on the Brookstone website.
http://brookstonemanuals.com/
Product number for Brookstone "Slide and Negative Scanner" is 598581 ... see back of your manual to confirm.
iConvert Film & Slide Scanner (598581) iConvert Film & Slide Scanner Drivers for Windows XP & Vista (119 MB)
Worked great for me!
Dec 31, 2010 | Office Equipment & Supplies
I HAVE YOUR FS-500 FILM SCANNER AND ARCSOFT PHOTOIMPRESSION 6 WHICH WORKED OK FOR A WHILE. RECENTLY I HAVE HAD A PROBLEM AT THE FINAL STAGE OF TRYING TO ACQUIRE DIGITAL IMAGES FROM SLIDES WITH THE...
A) Please refrain from shouting, it is considered rude.
B) Fixya does not sell or supply equipment of any kind - I really feel that your tirade should be directed to the supplier or manufacturer of the item you appear to be unable to operate - my advice is not to shout at them, as if you do so it is unlikely they will take it kindly either.
Jul 03, 2017 | VistaQuest VQ-350B Digital Camera
We have recently purchased a Film/slide scanner model FS-500-S (base). I have been able to put our slides through the scanner without any problems and they appeared on our computer. However, now I am...
Hi Bev.I have just purchased the same unit. It scans,but the colors are terrible. Anything what you would expect.also the installation software does not indicate the type of scanner I have. But i have sold my problem. It is in the bin. I will not touch a Base product any more.
Nov 23, 2010 | Office Equipment & Supplies
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
I've just bought a vistaquest FS-501 Scanner. I don't have an sd card for it. I've plugged it into my xp pc (using the usb cable supplied) after installing the driver. Now the led light comes on when I...
tweak the USB cable at the back socket of the box...there's a certain point where the cable will actually work and then you will have an image on the screen...sort of not quite completely fully in to the socket.
you're meant to be able to see an image on the screen and it's a manufacturing fault I think. good luck!
Jul 08, 2010 | Cameras
I bought a slide scanner FS-C1-BX2 Digotaaal Film & Slide Convert
I called the dealer an the walked me through the problem.
Ed Crafton
Jan 05, 2009 | Office Equipment & Supplies
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
VistaQuest Fs501-S1 Mini Film Scanner Vistaquest Logo
Top VistaQuest Office Equipment & Supplies Experts
k24674
Are you a VistaQuest Office Equipment and Supply Expert? Answer questions, earn points and help others
