Question about Sony PlayStation 2 (PS2) Console
The RGB setting at startup messed up my connection
Ok, well I was playing with the settings on my PS2, the system options you can get into if you leave the disk tray open. Well I changed one of the settings to RGB instead of the by cy or whatever. I thought I could do it because I connected my PS2 with the RGB composite cables to my Samsung HDTV. Well it just totally spazzed out. At first I thought it was just the TV not being able to translate the connection. So I tried on my Sony XBR HDTV and that didn't work either. So I tried the last tv with a composite imput, a SDTV Toshiba, and it still was a no go. I'm basically just asking if anyone knows how I can just reset the entire PS2 system so it would work the the standard yellow video input.
  • Josh Lee Jul 24, 2007
    Get get some sun kid, instead of wasting time on the net being useless like you are now
    Anyway I got it fixed, the RGB setting worked with the yellow video cable for some reason which allowed me to change the to the other setting to let me use the composite cables.
Ask your mum
Posted on Jul 22, 2007
SOURCE:
I have sony a DVD player when I play a movie, the movie is only in green
If it is connected with a scart lead you need to select the same system on the DVD that the TV is using, so if the TV is set to RGB on the scart input the DVD needs to be set to RGB and if the TV is set to CVBS the DVD should be. Check both in their respective menus you should always use RGB .
Jan 28, 2011 | Sony Televison & Video
How to fix lag on plasma to play ps2 guitar hero
Try to configure the following settings.
Go Video Setting, BD/DVD Cinema Conversion (Automatic), then BD/DVD Upscaler (Normal), then BD/DVD Video Output Format (RGB if you are using your PC Monitor, Y PbCb PrCr if you are on HD TV), then BD 1080p 24Hz Output (Automatic), then BD/DVD Dynamic Range Control (Off), then BD/DVD Audio Output Format (Linear PCM), then BD/DVD Audio Output Format [Optical Digital] (Bitstream). Go out of Video Setting and go to Display Setting. RGB Full Range (Limited), Y PbCb PrCr Super-white (On).
Hope this will help you.
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
I've connected the projector to my laptop using the VGA cable as stated in the manual. The projector reflects as it should, i can access the menu and input options which i then select RGB scart (though...
Not with any RGB input options, computers are not compatible with these. The projector needs to be set up to receive VGA. There must be a toggle button or menu entry somewhere on your projector that lets you do this or why would it have a VGA input?
Dec 07, 2009 | Sanyo PLC-XW55 LCD Projector
Can't play Madden '09 online with PS2
Have you checked all the settings in your router? wait...people pc is dial-up right?  I didn't think dialup will work.
Mar 04, 2009 | Sony PlayStation 2 (PS2) Console
Video out settings changed to RBG;Complete loss of signal
RGB is componet, you need to turn on the PS2 with the disk tray open or no game in it and go to system settings and change it to
Y/Pc/Br
which is composite.
Feb 01, 2009 | Sony PlayStation 2 (PS2) Console
Black and white picture
Since you're playing in a PAL region, it sounds to me like you're using the wrong connection for your system. You don't need to buy an SCART adapter for your cable, but if you pick up an RGB cable for your PS2 instead of composite, you should be fine. This is assuming you don't have a composite connection somewhere on your TV. Component (Y/Pb/Cr) would also be a good option. I can recommend a store here in the US, but I don't know if they ship internationally. The linked item is an S-Video cable, which will work well if you have an S-Video connection available. You can look for the other options on the site. Good luck!
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10830&cs_id=1083003&p_id=4008&seq=1&format=2
Jan 03, 2009 | Sony PlayStation 2 (PS2) Console
PS2 Star Wars Force Unleashed Game won't run
Another thing you might want to check is the system settings on the PS2. Start the PlayStation 2 console with no disk inserted in the drive. Upon loading to the main screen which states "Browser" and "System Configuration", press the X button on the controller. You will see five categories, highlight the PS Driver category, and then press the Triangle button once. Verify that both options within say "Standard". If they do not, then please use the steps below to change them.
- Use the D pad up and down to select the option that needs to be changed.
- Once the option is highlighted, press the X button once
- Use the up and down keys on the D pad to change the option to the Standard setting.
- Press the Circle button once to confirm the change
Next, use the D pad to select System Configuration, then press the X button. Using the up and down arrows on the D pad, cycle through the options on the screen and confirm that they read as follows.
Digital Output - Off
Component Out - RGB
Language - English
Screen - Full (This toggles the letterbox functions of the console, and may not be fully supported within the functionality of some games).
If any of the options are different from what is stated above, then, with the option highlighted, press the Triangle button. Use the D pad left and right to select the option that matches what is listed above. Once the correct setting is selected, press the Circle button. Once all the options are set as listed above, press the Circle button to return to the Main menu.
You may also want to try enabling the Auto-Diagnosis feature of the PS2, which will allow it to auto-detect the best settings to use when playing DVD's.
To Activate the Auto Diagnosis
- From the Browser and System Configuration menu.
- Press the triangle button to select Version.
- Highlight the Console from the list and press the triangle button - this accesses the next menu option.
- The Diagnosis will be highlighted.
- Press the X button to access the options available.
- Highlight "ON" and press the X button to affect the change
Dec 14, 2008 | LucasArts Entertainment Company Star Wars...
Ps2 wont read discs and asks for format disc
I can guess that the games you are trying to play have a Blue underneath and not silver. This was a big problem with my sons disks too using the older version of the ps2. We managed to mess about with some of the settings and changed the rgb setting to the other option (can't remember what that was now...sorry) and got some of them to work, but not for long. When the new games come out now they expect you to have the slimline ps2 and unfortunalty won't work on the older model. So to fix this problem I just bought a new one.
Oct 26, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2 DVD playback
nothing you can do about that I'm afraid, the PAL version of the PS2 just doesn't like playing them.
Nov 19, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
221 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
