Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
What is the torque specs for head bolts on a tecumseh hs50 67244f motor
2 Suggested Answers
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
I would like to know the torque specs to cylinder head bolts.
WELL MY CRYSTAL BALL BLEW A FUSE AND MY GENIE RAN AWAY WITH BRITANY SPEARS CAN WE POSSIBLY TELL US ALL WHAT KIND OF CAR AND WHAT MOTOR IT'S NEEDED FOR NONE OF US CAN SEE IT SO WE ALL CAN NOT HELP YOU UNTIL YOU DO THIS PETE POST BACK WITH SPECIFIC INFO O.K.PETE
Feb 20, 2015 | Cars & Trucks
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Head bolt torque specs and sequence for early 350 malibu motor
There are two different torque specs for this engine depending on which bolts you are torquing. This engine uses three different length bolts, the two sets of longer bolts can be torqued to 70 foot pounds, the short set of bolts that go along the bottom of the head should be torqued to 65 foot pounds. Head surface and block surface should be clean, straight and the a new head gasket should be used.
An easy way to guide yourself in the proper sequence is to make a cheat sheet of sorts. Take the headgasket and piece of cardboard about the same size. Using the headgasket as a template, mark each of the bolt holes on the cardboard with a sharpee marker, pencil or pen. Also outline the headgasket and mark the top of your drawing. Now starting from the center bolt as number 1, move either to the right or left, up or down to the next bolt hole and mark that as number 2. Now move to the bolt hole diagonally across from number 2, past Number 1 and mark it as number 3. Continue this sequence of moving diagonally back and forth across the headgasket outline until all of the bolt holes are marked with a number. What you are trying to do is start at the center of the head tightening it down in steps of about 15 foot pounds moving out from the center.
I have built a lot of these engines over the years and they are very forgiving of the head torquing sequence. As long as you start at the center and move out left and right, up and down alternating back and forth, you will have no problems. As a final check once you are done, check the torque on each head bolt to make sure you have not missed one. This does not have to be done in any sequence and you will then be sure that you have it completed properly. Good luck.
Apr 27, 2010 | Chevrolet Malibu Cars & Trucks
Need the head bolt torque specs for a 1999 grand am - i am trying to replace the heads on 1999 grand am with 3.4 engine
Fig. Cylinder head bolt tightening sequence-3.1L engines & 2001-04 3.4L engines
Fig. Cylinder head bolt tightening sequence-2005 3.4L engines
Hope this help (remember rated and comment this).
Mar 30, 2010 | 1999 Pontiac Grand Am GT
What are the torque specs for intake and head for a 1992 c 1500 chevy silverado. I need to know the torque specs for intake and head for my engine
For 1988-1995 4.3L,5.0L and 5.7L intake manifold bolts are torqued to 35ft.lbs.Start with center bolts on each side moving out finishing with the bolts in the front of the motor and the back
Oct 24, 2009 | 1992 Chevrolet C1500
4HP Tecumseh flat-head head-bolt torque?
check the numbers on the motor and you can contact Tecumseh or check their website for info, they are usually very good with their help
Jun 29, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Cylinder head torque specs
200in.lbs
16.5ft.lbs
22.5Nm
Mar 26, 2009 | Craftsman Garden
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
75 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
