Question about Microwave Ovens
Oven does not operate
Had a very small fire inside oven and now nothing works including clock, does not give any indication that its getting power. although out let will operate other appliances, did not hve to use water or fire extinguiser, with the exception of a little black soot and burnt smell you would not know there is a problem, very minor cleanup required.
  • 5 more comments
  • Mark T White Jan 28, 2009
    Hello, its a GE model # JVM1563WH05, have sides and top of cabinate off (all one cover) cant see anything that looks out of ordiary found one fuse near controll simaler to older automotvie says 20 amp on one end body is coverd so I cant tell if its blown by looking but put ohm meter and read across ends and it does regester so assumed it was ok and reinstalled it, also put meter across what looks like small round sensers located in various places around oven and havent found one yet that wont register or make the needle on meter move Thanks
    Had automotive type fuse out of circut when tested , all other small round ( about the size of a dime) sensors? were tested in circut, havent yet located bullet shapep thermal fuse. fire was not that big ,only slightly blackend inside of oven. Would thermal fuse be located some where above oven roof/top ? this would probbly be the only aera where fire got hot enough. no signs of any plastic parts being distorted.
  • Mark T White Jan 29, 2009
    Thanks I belive Thats the problem
  • Mark T White Feb 01, 2009
    found sensor parts wharehouse labels it a thermostat ? any way orderd and on way , new problem is what to use to clean up black soot stain , some wiped right off with normal kitchen cleaners , some is on really tough. Help.
  • Mark Egan May 11, 2010
    Did you test the fuse out of circuit, or in circuit?
    The other things that you measured, did you test in circuit, or out of circuit?
    There are not that many components to measure. Fuse, diode, rectifier, capacitor, and the only one you can get a decent indication on would be the fuse, but only if measured with it out of circuit.
    Can you trace the power wiring as it routes through the unit? Check for power at various points along the circuit until you come across a point that power does not go across (like the fuse).
    I am thinking you need to look for a silver bullet shaped thermal fuse which could have melted due to the fire (again, I don't know how big or hot the fire got, and whether it got hot enough to damage something else is at question.).
    Please provide the specific model number, but I bet there is some electrical damage inside the unit. You need to open it up and tell us what you see.
    There is a fuse that could have failed, but be careful that you watch what your doing when you power this unit up. It could be dangerous.
  • Microwave Ovens Master
  • 9,086 Answers
I assume that model is JVM1653WH05?
The fire probably opened the internal flame senor, also known as the oven cavity thermal cutout (TCO) located on top of the cavity.
The TCO part number is WB27X10195 and it's available here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams here.
Accessing the cavity TCO will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 29, 2009
  • William Miller
    William Miller Jan 29, 2009
    I mean "flame sensor", not senor.. lol
  • William Miller
    William Miller Jan 31, 2009
    Did you mean to award that "FixYa" rating to my solution? *grin*
    President:
  • 1,214 Answers
It's usually in the wire bundle leading to the controller board, if there is one. There should be a wiring diagram/schematic somewhere on the unit. You should be able to chase the circuit down from that.
If not, I'll try to find one online.
Posted on Jan 28, 2009
  • Mark Egan Jan 29, 2009
    Thanks! Glad you got it going again!
  • Mark Egan Feb 01, 2009
    If it's painted, then there is a paint available for microwave ovens. The paint that's there is most likely a powder coat. You won't get much better than that, and powder coating is not a process you do at home.
    If it's stainless, then go to a hardware store and get a medium and fine scotch-brite pad. Between that and some Braso, that will be the best you can do.
I accidentally put metallic threads in my ge microwave (PVM1870SM1SS); caught fire and shut down all the power to the microwave. I have no power at all no light or clock...no nothing Is there a internal...
there is an internal fuse,if your lucky thats all it is,but if there was an actual fire then it may be time for a new unit depending upon the extent of damage
Jul 16, 2010 | General Electric Microwave Oven
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Door latch and Screen
This is because of the broken latch. There are switches inside the oven that are operated by the door latches to make sure you're not trying to use the oven with the door open. With the new door, your oven should be back to normal.
Feb 06, 2009 | Whirlpool Microwave Ovens
Ge model Jvm1563wh05 microwave oven
Jan 27, 2009 | Microwave Ovens
Frigidaire GLMV168CS1 Microwave - Sensor Error
If you are handy take it apart. Somewhere inside is a small switch that the door activates. Switch might be broken or a small plastic actuator might be broken. What do you have to lose at this point except time?
Jan 09, 2009 | Microwave Ovens
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
SET CLOCK. TRY TO USE. IT SHUTS OFF AFTER A FEW SECONDS.
I found an envelope with troubleshooting info inside the microwave on the left side behind the front vent. A troubleshooting flowchart was included which indicates that this problem is caused by the high voltage capacitor. I got mine out pretty easy and ordered one from appliancepartspros.com for $55 (which includes expedited shipping. I hope this info helps.
Sep 05, 2008 | GE JVM1650 1000 Watts Microwave Oven
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool microwave/oven model RM286PXV3
Just so I understand, you replaced the fuse inside the oven? If so, I would suspect a bad thermostat attached to the magnetron. This device interrupts power when the unit gets too hot. I've included a representative photo. After so many years your magnetron may be bad, too. Once you get the oven working, if it cooks and doesn't trip the thermostat again, it may be okay. PLUS - It looks like this model has manual rotary controls. If so, it's common for those to develop bad contacts after so many years. I would consider that my third suspect. Those controls are called the thermostat (not to be confused with other part by that name that I discussed above) and the selector switch. One could easily be bad. You can check part prices at Sears online at http://www3.sears.com (the "3" is supposed to be there) Some other things that can cause a "dead" condition: - bad connections on the small circuit board where the fuse is mounted (if such a board is present) - bad connections in the wiring Good luck.
Nov 04, 2006 | Whirlpool MH1140XM Microwave Oven
Microwave Ovens Logo
132 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
