Question about Aroma Rice Cooker Aroma 10-Cup Cool-Touch Rice Cooker, Stainless - ARC-940SB
ARC 940S parts
Filter
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
Arc fault breaker in Bedroom,trips when I plug in my computer laser printer,the printer works ok in any other outlet in the house except the master bedroom that is protected by a arc fault breaker.
My experience with these breakers is that there could be some minor short in the equipment that cause them to disconnect. I have a filter motor that will not run on my ground fault breaker if it gets wet. There may be no problem with the breaker.
Gary
Jan 07, 2011 | General Electric G.E. Arc Fault Breaker
Already replaced the clutch fan on our 98 isuzu rodeo but now it revs up when first started until it finally changes gears then it doesn't do it anymore until the next time it is started. Thought maybe we...
The fan has an arc to the individual blades. The inside of the arc goes to the rear, and of course the outside of the arc points to the front. Imagine if the blades were cut out of a very large piece of metal tube, the arc or curve of the blades would still be visible as you look at the individual fan blades. This is the arc I was speaking of. The part of the blade that would have been the inside part of the very large piece of metal tube, the blades cut from faces the rear, and the part of the blade that was the outside of the tube faces forward.
Dec 20, 2010 | Isuzu Rodeo Cars & Trucks
Water to rice ratio in an Aroma ARC 1000
Water to rice ratio is usually the same regardless if you have a rice maker, or are cooking it in a pot on the stove. 2 parts water to 1 part rice works everytime.
Jun 08, 2010 | Aroma ARC-930 20-Cup Rice Cooker
Replacing fuel pump on 1992 Volvo 940
look in autozone, look up the part n then click on "view job diagram" hope that helps
Feb 28, 2010 | 1992 Volvo 940
Volvo 940s 1992 radiator what type do i need
alummnum withe plastic tanks w/temp switch
Sep 27, 2009 | 1992 Volvo 940
Hobart Ultra Arc 350 3-phase blows breaker in fuse panel
if you have a airgas dealer they carry hobart parts im not sure why you are blowing circut brackers unless they arenot big enough
Aug 17, 2009 | Welding Tools
Microsoft arc mouse USB miro transreceiver
No you cant buy from Microsoft nor I've been able to find anything in the net. Microsoft representative suggested buying a new mouse
Jun 07, 2009 | Microsoft ARC Mouse
The ozone generator quit working. What is the problem and where can I get parts ?
You can pull off the rear filter, pull the ozone plates, defeat the safety interlock, turn the unit on, and place a screw driver (holding the plastic handle) one one of the ozone bars, and try to make an arc between the screwdriver and the other bar.
If you get an arc, the ozone plates are dirty. Clean well with a brush and sudsy ammonia. If no arc, either the hv transformer is bad, the main circuit board is bad, or the ozone control is bad.
There's one other thing you can check: The two wires that connect to the ozone bars can arc to the chassis sometimes. You can inspect the insulation on those wires to make sure it is intact.
May 12, 2009 | Eagle Advantage Alpine Air Purifiers Eagle...
Aroma Rice Cooker Aroma 10-Cup Cool-Touch Rice Cooker, Stainless - ARC-940SB Logo
57 people viewed this question
Top Aroma Rice Cooker Kitchen Appliances - Others Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
dante
Are you an Aroma Rice Cooker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
