Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP All-In-One 6110 Prints Only Intermittently
Hello - I have an HP All-In-One 6110 printer. When I send items to it to print, it actually prints only about 40% of the time. When it doesn't work, the printer cartriges run lightly across the paper as though it is printing but is not - it sounds similar but you can tell it is not working. Sometimes if I shut it off and turn it back on, it will print, other times not. Any ideas? I am using an HP Pavillion a1040n and it is connected via USB, but have tried using it with other computers and it does the same thing.
Thanks
Dave
  • Printelogy May 11, 2010
    Have you tried with a different USB cable?
    Genius:
  • 2,120 Answers
Replace the ink cartridges with GENUINE HP carts.
Posted on Jan 28, 2009
HP 6110 Officejet all-in-one will not print from the glass top. It will make prints coming from the computer after I press "enter" from message "paper jam". I also can fax. Please help.
You will need to open the top and look inside where the paper travels through and attempt to free any paper pieces that have gotten stuck in the pathway. You probably have a bad board in your control panel, since you are able to print from the computer.
Feb 20, 2013 | HP OfficeJet 6110 All-In-One InkJet...
My hp 6110 prints slowly
Hello
Well for the said problem there are 2 possibilities
1. The setting might be for best and that is why it is printing slow.
2. If the Black cartridge is bad it also slows the printer.
First try to see the settings to make it normal. Later try to replace the cartridges and it will surely solve your problem.
Jul 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 all-in-one.....Connected to PC correctly...it has ink.....it prints a report...BUT it will not make a copy when an item is placed on glass and it will not print when right clicked....What does do...
Try printing it from the ADF (Automatic document feeder) if it prints from there... If same thing happens just check if the scanner bulb lids up or not... If not then its the issue with the scanner bulb
Oct 21, 2010 | HP Photosmart C6100 All-In-One Printer
HP 6110 PRINTS VERY SLOW
You're probably using a high quality print setting. Try accessing your printer preferences and selecting "Draft" quality. See if that's any quicker.
May 17, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My HP officejet 6110 only prints in black and white
Every time I try to print I get a message saying that The Spooler service is not running, what should I do?
Feb 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 printing double
Try copying. check its there or not.
If not, try unchecking all the options in the print options and try. then check zoom to fit. then try
Mar 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Oct 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Prints part of the page and then restarts
Connect it back to the computer and verify it's still working properly that way. It does indeed sound like a compatibility issue, but it may be correctable with a quick chat with the friendly folks at NetGear.
May 11, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
