Question about Craftsman 12 Tilt Head Band Saw Owner Manual 113247210
Need manual for 12 bandsaw-sander 113.243310
Got it used and it does not have manual
4 Suggested Answers
ToolBoxHero
  • 171 Answers
SOURCE: Sears 12" bandsaw Model 11324200 I
Here is a link to the parts diagrams.  You can order new parts and have them shipped right to your home.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113247210/0247/0744100?pathTaken=
Posted on Jan 06, 2011
  • 5603 Answers
SOURCE: how to find value of used 12' bandsaw + sander
Look on Ebay.com for auction value. Look in completed auctions for those that have sold. With the inexpensive new tools from Harbor Freight the value may be considerably less than expected.
Posted on Apr 23, 2011
How do you remove the upper wheel on a craftsman 12 inch bandsaw
Check with bandsawmanuals.com if they have the manual for your band saw. You might want to try these steps. First, you need to unplug the saw and remove the band. Then remove the outside snap ring.
I am not sure but you might have to remove the self locking screw in the shaft.
Once the snap ring is removed, you should be able to remove the wheel and the outer bearing.
Then remove the back bearing from the shaft. Next, install the bearings in the reverse order.
Aug 29, 2014 | Craftsman 113.243300 & 113.243311 12" Band...
My Craftsman Bandsaw's (Model 113.243310) tension wheel is bouncing the blade off every time I turn it on. Any suggestions?
Please be sure that your put correct tension on the blade. Check the blade guides and check if the blade is tracking
properly. Make sure the tires are clean. If they're well worn out, change them . You may try to install new blades too.
Feb 18, 2013 | Craftsman 113.243300 & 113.243311 12" Band...
How to find value of used 12' bandsaw + sander + legs #113243300 + 11324310(stand)
Apr 23, 2011 | Craftsman Saws
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I am changing the saw blade on 12 inch Craftsman bandsaw
Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will bring you a series of parts drawings and possibly an owner's manual. Generally, adjustment is provided for the upper wheel only--use hand power to check the tracking performance. Good luck!
Jan 12, 2010 | Saws
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Craftsman 12 Tilt Head Band Saw Owner Manual 113247210 Logo
204 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
