Question about Canon Office Equipment & Supplies
Ink tank not working
One of my ink tanke doeo not flow
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Reset chip ink cartridge expired
The HP cartridges have a date-encoded chip. It cannot be reset. However, I have been using a tank-type inksupply from ink2000 (see ink2000.com) for my HP Officejet L7500 for years, and I've recommended the corresponding system to friends with other HP printers. Ink2000 makes a quality system that comes with an external transparent Lucite ink tank that connects to most printers. No-mess refill of the ink tank is trivial and you can visually see when it's time to fill the cells. A capillary tube runs to specially modified replacement cartridges that are supplied by ink2000 when you purchase the system. These cartridges install in your printer just like the HP cartridges. I have but one precaution for you, and this holds whether you use the ink tank system or not.
The design of the HP printers that have the cartridges installed in the printhead (unlike my model which has them installed in a fixed location) is deficient. Without regular use the ink dries at the printhead. Worse yet, air enters the cartridge causing its special foam insert to dry out. You MUST USE YOUR PRINTER regularly for at least brief time to avoid this. When you use the ink2000 inktank system you can use a syringe placed over the top of the affected tank to force air pressure gently into the capillary to make sure ink (and not air) is fully flowing into the cartridge.
If you lift out the cartridge from the printhead and place it over a paper towel, you will see ink begin to flow immediately from the cartridge if it's not clogged or dried out. Apply air pressure slowly until you see ink just begin to emerge. Don't try to flood the printhead by getting too much ink out of the cartridge. Then reinsert the cartridge into the printhead (which previously has been cleaned) and try a few print cycles. If you have not destroyed the printhead this will work.
Jan 31, 2014 | HP C6250 InkJet Printer
How do I empty an ink absorber that is almost full?
The answer is that you don't empty it. Ink absorber or over flow tanks are not usually emptied. They are replaced. The removal process is different for each manufacturer and/or model printer. You didn't say anything about the model and make or I could be more specific.
Contact the maker of the printer, check the price for a replacement ink absorber or over flow tank and they will give you instructions on removal and disposal of the full tank. Depending on what printer you have, it may be more practical and less expensive to purchase a new one instead.
Jun 04, 2011 | Office Equipment & Supplies
Hi, I am having a problem with my relatively new canon ip100. Since I installed new cartridge for black ink, when I run the test of nozzle it shows that black print head needs cleaning: missing parts lines...
Welcome to FixYa!
Here are my suggestions:
Confirm that the Ink Tank is installed properly.
If the ink tanks are not loaked into place, the will not be supplied to the print head.
Remove tape from the
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
Confirm there is no orange tape across the top of the ink tank.
Try to use other Black Ink Cartridge. The cartridge might be defective.
I hope this helps.
Thank you for using FixYa.
Keep me posted.
Jas247
Mar 31, 2011 | Canon iP100 Portable Printer
Cannot get the magenta ink tank to flow in a Cannon Pixma 4500
Yes, you can take the printing head out  and soak it up in hot water. You can even blow some air on it, this will dislodge even the nastiest dried ink gunk. If even after that the head doesn't work then it's dead - buy a new printer.
Jul 11, 2010 | Canon Office Equipment & Supplies
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Ink tank error message Canon iP3500
Canon ink tanks contain a chip allowing the printer to identify genuine ink tanks. You need to buy reasonable quality replacement ink tanks i.e. from (Google) 'Inkjets & Toners'
May 01, 2009 | Canon PIXMA iP3500 Printer
Waste ink tank over flowing??
Hi, like every ink jet printer, there should be an ink pad(spunch) at the bottom of the printer to collect the waste. That spunch might be full of ink. You could locate it, remove and try to clean it under the water. See if it works
Apr 03, 2009 | Canon i860 InkJet Photo Printer
Canon i960 will not print in black ink
Yep same as above. Black prints very light gray after 5 years of good printing. Tried every test, replaced black cartridges with different brands. Just wondering if somehow you can clean the heads. I'm convinced the black head is almost totally clogged. Does anyone know how to remove the printer heas to do this?
Apr 01, 2008 | Canon I960 InkJet Photo Printer
Ink tank lamp lights not coming on when ink cartridges installed
Remove tape from the ink tank - MP800R / MP830 / MP530
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads. It is necessary to adjust air pressure outside and inside the tank so that ink flows properly. If ink does not come out, check to make sure that the protective film has been correctly removed.
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    Caution:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the tab to release the ink tank (1), then remove it from its slot (2).
    Caution:
    a. Do not remove the print head from the machine.
    b. If several ink tanks need replacing, remove and replace each one individually.
  5. Check the ink tank. If the orange tape is as shown in Figure (1), it is properly removed.
  6. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  7. Insert the ink tank diagonally into the print head.
  8. Press it in firmly until it locks into place.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  9. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  10. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Dec 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
46 people viewed this question
old marine
old marine
