Question about Whirlpool GU2400XTPS Built-in Dishwasher
Bottom spray arms will not turn
Water fills up in the bottom of dishwasher but the bottom and top spray arms won't turn.
  • tannykreutz Feb 13, 2009
    Water is coming through the water inlet valve, I just replaced it, but no water comes through the spray arms. Kenmore built in
  • 29 Answers
Posted on Jan 28, 2009
Maytag quiet series 200 dishwasher spray arms won't turn
Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them.
You may find answers here:
Jan 15, 2013 | Maytag 24 in. MDB4000 Built-in Dishwasher
I have a Frigidaire dishwasher, PLD4460. Only 4 years old. The dishes on the top rack are not coming clean anymore. Something as simple as left small bits of broccoli do not even get rinsed out of the...
If the top rack of the dishwasher doesn't get clean, check your appliance to see if you can fix the problem.
First check the spray Arms to make sure the holes in the spray arms are free and clear of debris. Your dishwasher should have several spray arms, including one at the bottom of the tub, one under the top rack, and possibly a third spray arm on the top of the tub. Sometimes food and mineral deposits can block holes in the spray arms, preventing water from spraying effectively. If this occurs, warm some white vinegar and pour it into a spray bottle. Spray the holes with the vinegar and dislodge debris with a toothpick or large safety pin.
Then check to see if your dishwasher has clogged filters. Filters generally cover the drain valve area to catch debris as the water drains from the dishwasher. Many dishwashers have maintenance-free filters, but your dishwasher may have filters that need cleaning. Read your owner's manual before you perform any filter maintenance to avoid damaging your dishwasher.
Check your water temperature to make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not be hot enough to clean dishes effectively. Turn your kitchen hot water tap on and wait until the water warms up completely. Fill a cup and measure the water temperature with a kitchen thermometer. If the water is less than 120 degrees Fahrenheit, turn your water heater up to 120 degrees.
Load the top rack properly. Place cups and bowls upside down in the rack and don't nest dishes because this can prevent water from reaching dishes. Don't overload the top rack. Instead, position each item so the dirty areas of the dishes will receive full contact with water spraying up from the main spray arm located beneath the top rack. Prevent items from hanging below the top rack, which could prevent the spray arm from rotating.
Also check this link for more helpful info:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Aug 15, 2011 | Dishwashers
The top spray arm is not turning as best i can tell. bottom one is.. frigidaire model # fdb1050rec2. please help! thank you
If your dishwasher does not fill up with the correct amount of water the top spray arm will not get the water pressure it should.
The water level should be just under the heating element.
Aug 03, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
Will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Open Questions:
See all Whirlpool GU2400XTPS Built-in Dishwasher Questions
Whirlpool GU2400XTPS Built-in Dishwasher Logo
123 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
