Question about Facebook Apps
Mini project for passport automation system - Facebook Apps
2 Suggested Answers
  • 3 Answers
SOURCE: want diagrams for passport automation system for
GO To this http://9.bb/Bme
Posted on Feb 11, 2011
What is the difference between Manual vs. Automated Testing?
Difference between Manual and Automation Testing is the pillar of Software testing, because whole testing is based on Manual and Automation Testing. In a project you can do either Manual or Automation Testing and you can also do both Manual and Automation Testing simultaneously.
Complete Difference between Manual and Automation Testing
Manual Testing Automation Testing 1. Manual Testing is a process which is done manually. 1. Automation Testing is a process which is done by the help of automated tools. 2. All the famous phases of STLC like test planning, test deployment, result analysis, test execution, bug tracking and reporting tools are obviously comes under the category of Manual Testing and done successfully by human efforts. 2. In Automation Testing all the popular phases of STLC are done by various open sources and purchased tools like Selenium, J meter, QTP, Load Runner, Win Runner and so on. 3. Manual Testing is a start of Testing, without this testing we can't start Automation Testing. 3. Automation Testing is a continuous part of Manual Testing. 4. In Manual Testing testers are allowed to do Random Testing to find the Bugs. 4. In Automation Testing we always test through Running Scripts. 5. In Manual Testing we find more bugs than automation by Error Guessing. 5. In Automation Testing we test the repetitive functionalities of the application. 6. It takes lot of time. 6. It takes less time. 7. Manual Testing would be run sequentially. 7. Automation Testing is done on different machines at same time. 8. Regression Testing process is tough in Manual Testing 8. Regression Testing process is easy in Automation Testing by Tools. 9. It is not expensive. 9. It is expensive. 10. More testers are required in Manual Testing because in this testing test cases need to be executed manually. 10. Few testers are required in Automation Testing because in this testing test cases need to be executed by using Automation Tools. 11. It gives low accuracy result. 12. It gives high accuracy result. 12. It is considered as low quality. 12. It is considered as high quality. 13. In this Testing we cannot do batch testing. 13. In this Testing we can do multiple types of batch testing. 14. It is considered as less reliable. 14. It is considered as more reliable. 15. No need of programming in Manual Testing. 15. Need of programming is must in Automation Testing. 16. It is done without interaction of any Tool. 16. It is always done using tools.
Aug 24, 2016 | Microsoft Video Game Consoles & Games
Tip
Mobile automation testing tools
http://mobilelabsinc.com/
The means of automation are usually chosen subjectively depending on project needs and application type. Among good paid automation tools available today are Ranorex, Silk Mobile, SeeTest, etc. There are also worthy free tools like Appium, Robotium, KIF, Calabash, etc., but using these requires certain coding skills such as Java or Ruby.
on Nov 23, 2016 | Miscellaneous
I need ooad lab coding for passport automation system
Jan 15, 2013 | Computers & Internet
I need visualbasic 6.0 mini project
here is the download link for your visual basic6.0 mini project
http://softwaretopic.informer.com/visual-basic-6-mini-project/
choose according to your wish
"be free to ask further help...am here to guide u based on computers:-)"
Jul 23, 2011 | Computers & Internet
I have a WD Passport drive that I want to use through a Targus mini USB hub. The Passport drive has power, but it will not install through the hub. Apparently wants a driver and apparently they don't have...
The reason your full sized drive works fine and the passport doesn't is that the full sized drive has it's own power supply and only uses the USB for data transfer. The Passport drive requires much more power from the USB to spin up, so, if you want to run it through the USB hub at the very least you will need to replace the USB hub with a powered one.
As for a driver, you don't need one to use the passport on XP that's why you can't find one but the Passport does require a dedicated port(2 for Amperage on some systems) or will need to be plugged into a powered hub or it simply won't get enough juice to fire up. That is the reason it won't show up.
In short, buy a powered hub, or plug it in direct. Nothing else is likely to work.
Hope this helps figure it out
Chris
May 07, 2009 | Western Digital Passport 320GB External...
Send me the related titles to develop a projects in c,c++,vb
in C/C++ you can have projects related to system/hardware, maths and engineering.
while in VB you can create Database/Interface oriented projects. The related titles are :--
C/C++
1. Serial/Parallel port communication
2. Automatic weight entry from Weighing Machine
3. Your weight on different plannets
4. PC based PH Meter
5. Electronic Punching/Kicking pad to measure power of martial arts/boxing players
6. Electronic man counter
VB
1. library management system
2. Video Library
3. Virtual Library
4. Automated Parking Management system
5. Automated Car security check (Bomb finder)
6. Automated ID Card generator
7. Face recognition responsive system
Dec 08, 2008 | Computers & Internet
Facebook Apps Logo
75 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Facebook App Expert? Answer questions, earn points and help others
