Question about Brother MFC-685cw InkJet Printer
I have a brother MFC-685CW sitting in my bench, it has an error that states "Unable to init. 52" the machine decides to cancel any sim that I run in the maintenance program such as, 01, 76, 04 etc.
Brother MFC-685CW, Error: "Unable to init. 52" I have tried running initialisation tests, cleaning tests etc, but it's all the same result as the copy or print functions, "bleep bleep", everything cancels itself and pops up with the before mentioned error. I have tried to use, Menu -> Black Start -> Menu -> Black Start -> 01, 04, 76 and others, they all come up with the same result. Cn you guys help me out at all?
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Posted on Oct 22, 2008
BubbaGuru
  • 70 Answers
SOURCE: ! Unable to print 36
here is the solution according to brothers website
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000012648&Sympt=How+do+I+clear+error+message+Print+Unable+36%3f&Model=1208&ProductGroup=1&ProductID=HL4070CDW
Posted on Mar 23, 2009
  • 159 Answers
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Posted on Jun 11, 2009
  • 265 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc 685cw jammed then get error message
Hi can try this
Hi there
Brother 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
Brother mfc 240c machine error 40
Unplug the machine from the AC outlet and if possible cool the room where the machine is located.Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother Multi-Function Center MFC-240C...
Unable to init. 4f in Brother MFC j615w
Sorry to say this error refers to a print head failure. It is not a user changeable part. It will need repairing by a Brother service agent and it will probably cost more than the printer is worth.
Mar 14, 2014 | Brother MFC-J615W Compact Wireless Inkjet...
My brother mfc 495cw keeps giving an "unable to init." error message. chris.iya@lausd.net
Hi. my machine model MFC 495 CW. I did any step but my machine till show up unable to Init. 4 F. please can you help me about that. thanks you very much
Tien
Sep 07, 2010 | Brother MultiFunction Center MFC-440CN...
My Brother MFC 440CN will not print
printer 440cn does not print. you call the printing option and the printer icon star jumping for a while then stop.I then open the printer queue and it is empty. I am running mac OS 10.58 in my Imac
Jun 20, 2009 | Brother MFC-440CN InkJet Printer
Unable to Init. 46
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
Dear Guru,
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
BROTHER MFC210-C "UNABLE TO INIT"
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Apr 03, 2008 | Brother MFC-5440CN All-In-One InkJet...
Unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Mar 13, 2008 | Brother MFC-620CN All-In-One InkJet...
Brother MFC-685cw InkJet Printer Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
