Question about Canon PIXMA Pro9000 Printer
No paper but there is
Keeps giving me no paper but there is ..
  • Dean Lohre
    Dean Lohre Jan 23, 2013
    it grabs the paper and then gives me error 1000
  • 5,678 Answers
Paper must be in right postion
Posted on Jan 23, 2013
Keeps coming up paper jam code 3528 new printer no paper in back cover removed no jam found
There may be a small piece of paper in the back that is causing the sensor to give you the error message.
Printers give jam messages when a sensor is being blocked by and object.
If there is no paper causing this, you probably have a sensor problem.
Try unplugging the printer and plugging it back in.
Mar 02, 2011 | Office Equipment & Supplies
Hp officejet 9130 keeps giving me a paper stall message. Paper keeps jamming
I am having the same problem and can tell you that it is NOT related to the paper roller assembly. I purchased a new OEM part and replaced them.
Jun 11, 2010 | HP OfficeJet 9130 All-In-One Thermal...
Paper feed keeps jamming
There could be something blocking the paper input, turn it upside down and give it a shake, or if possible take the top off and have a look around for any obstructions
May 20, 2010 | Dell 946 All-In-One InkJet Printer
My HP 2175 PRINTER keeps giving me an error
Check the default paper settings in the printer sofware, if they are correct then problem may be internal.
You dont mention whether it prints OK though.
Dec 01, 2009 | HP PSC 2175 All-In-One InkJet Printer
Canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Sep 17, 2009 | Canon PIXMA MX310 All-In-One Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
My printer (Epson R800) keeps on giving me the error 'Media not loaded correctly'. Even before it's even tried grabbing the paper, it starts blinking red on the paper/trash button. I've never had this
Please make sure that the paper that you are using is included under the printer's paper compatibility list.
Make sure that you are selecting the correct paper type on printer settings.
Trash and re-install the drivers.
Apr 29, 2009 | Epson Stylus Photo® R800 InkJet Printer
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
Canon PIXMA Pro9000 Printer Logo
19 people viewed this question
old marine
old marine
