Question about NorStar M7324 Telephone
Feature 71 I tried to link a call to my bosses cell phone using the feature 71 this morning but i cannot get it to work
  • NorStar Master
  • 2,460 Answers
If you have a manual, look up RECALL or FLASH or LINK. Specifically Feature 70 and FEAT 71. In your spare button set, you probaly have gray buttons labeled CONF/TRANS and LINK. Now you use them depends on how you are transferring calls. Are you on Centrex or do you have 3 way Conference calling from the telco? That's the one where you can establish a 3 way call and hang up and the other two parties stay connected. If you have that, you'll use the LINK button to get second dial tone, dial your number, and press LINK again to establish a 3-way. LINK time is defaulted at 600 mS, and is adjusted in A 4. Misc programming under LINK. You may just have 3-way calling, and that means the middle party has to stay on the call.
If you don't have 3-way conferencing, you can use the system to conference (using two lines), and the CONF/TRANS button. There may be some disconnect supervision (ie DS cabinet) issues, Supervised/Unsupervised programmnig changes, and transmission losses in conferencing, so your mileage may vary. Best would be maybe to conference with a VoIP trunk or other lossless facility. Anyway, you put the first call on hold, make the second call, then press CONF and the held line to establish a 3-way. At this point, if you have Disconnect Supervision, you can press conference again and leave the call, or put the call on HOLD to keep it on your phone and the other 2 parties can still talk to each other.
Carl
Posted on Jan 28, 2009
When I try to use my e 71 camera. it says : feature not supported. How can I fix this problem
Remove your memory card, do a backup of all your contacts and data, and then format it.
After doing the above, type: *#7370#
This should solve the problem. If it persists, try a firmware update using Nokia Software Updater.
If that fails, then its time for a dealer visit, its a hardware problem then.
Mar 13, 2011 | Nokia E71 Smartphone
My Nokia E 71 Model gives the message Camera Feature Not Supported error when i try for using camera. i tried factory settings, updating software options. but it gives the same result. Please...
Did you try formatting the phone memory and re-installing the complete OS of the phone?
This may have occured due to some error in your phone software or a virus.
Thank You.
Feb 13, 2011 | Nokia E71 Smartphone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
We have a Nortel T7316E & want to transfer live calls to cell
transfer (under screen when on a call) is for internal transfer. you need the external transfer feature from your phone company, then a "link" key programmed on your phone. link is also feature 71. when on a call you hit link or feature 71, then dial the cell or have speed dial buttons for them,.
Apr 20, 2010 | Nortel T7316E 2-Line Corded Phone
How do I program my link button
It can be programmed on your set by entering feature *3 pressing the button where its to be located and entering in feature 71.
Feb 18, 2009 | NorStar M7324 Telephone
Feature 71 on my meridian M7324
Feature 71 isa link key. It generates a link signal(also known as hookflash, flash, recall, or tap). it can be programmed on your set by entering feature *3 pressing the button where its to be located and entering in feature 71.
I think thats all to know about a link key, hope that helps.
Jan 27, 2009 | NorStar M7324 Telephone
Having problem programming personal speed dial on norstar 7208
Sounds to me your trying to access your speed dial bins feature 0 then your speed dial will get you to the speed dial bins 71-92 this is your personel spedd dials your phone only 0-70 are system wide speed dials . Feature * 4 is not a feature in norstar systems.
Sep 26, 2008 | NorStar T7208 Corded Phone
NorStar M7324 Telephone Logo
149 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
