Question about Sewing Machines
My Bernina 210 Activa won't power up. I had it tuned up by a Bernina tech a few months ago and this is the first time I've pulled it out. No power/nothing. Seems like I'm just missing som
  • Sewing Machines Master
  • 1,564 Answers
Seems silly, but did you remember to plug it in? If you used a power strip, did you remember to make sure the strip is turned on?
Make sure the connection is plugged into the machine.
Good luck
Posted on Jan 23, 2013
Zenqi
  • 208 Answers
SOURCE: I have a bernina 210 model sewing machine. I'm
#1 Use only Mettler or Gutermann thread. Coats thread is very rough and will pucker the fabric. #2 Make sure that the tensions are balanced. #3 Use the regular zig zag foot. #4 Use a new needle, universal, size 80/12. A blunted point will pucker the fabric.
Posted on Jun 02, 2011
  • 11 Answers
SOURCE: needle threader is not working bernina 220 activa
Use a magnifying glass to see if the little hook in the needle threader is bent so that it is not going through the eye of the needle. You might be able to gently bend it back with tweezers.
Make sure that your needle is in the upper most position when you try and the presser foot is down.
Posted on Mar 17, 2010
Zenqi
  • 208 Answers
SOURCE: My Bernina Activa 240 won't
Likely the problem is a blown fuse in the S-Print (power supply). You must have a grounding wrist strap when working with a Bernina Activa. They are extremely sensitive and can easily destroy the main circuit board if you don't use a wrist strap. You can get one at Radio Shack for less than $5. The power supply is the square 1/3 of the machine on the back on the handwheel side. You can remove the power supply by removing the long torx screw on the rear of the machine and tilting out enough to unplug the connector. Then dismantle the power supply until you can get to the fuse. Test the fuse with a continuity tester. If the fuse is blown, buy an exact fuse. Don not deviate. If the fuse is not blown, you may need a new power supply.
  • 166 Answers
SOURCE: Bernina Activa 130 I was sewing
You can check whether the alignment/timing has been affected fairly simply, as follows: Put a new needle in. Adjust the position of the needle fully to the left and try a straight sew-off ... if this works OK, but not when the needle is at centre, the timing is probably out. Drop the bobbin door and take the bobbin/bobbin case out. Turn the handwheel until the needle goes down into the stitch plate and just starts to come back up ... stop there. Carefully push the needle/needle-bar all the way to the right, so that the needle is nearly against the right-hand side of the slot in the stitch-plate. Lean the machine slightly back so that you can see clearly into the hook/shuttle area through the bobbin door. Release the hook/shuttle retainer by pressing the metal lever to the top-left side of the bobbin door. The black plastic hook/shuttle retainer should pop-open and you can carefully drop it down on its hinge to rest on the bobbin door. You can now see the hook/shuttle in its hook race and the pointed part of the hook should be to the left of the needle. Now, slowly rotate the handwheel so that the point of the hook continues to rotate clockwise until it just passes behind the needle. Look very carefully - the point of the hook/shuttle should be just above the top of the thread hole in the needle .... if it's below, or significantly above, the timing on your machine has been thrown-out by the needle breakage and will have to be professionally adjusted.
Posted on Oct 14, 2011
  • 166 Answers
SOURCE: Bernina Activa won't turn on
Lets start at square-one. Have you checked the plug fuse ? Have you checked that the 2-pin mains plug is firmly inserted into the socket on the back of the machine ?
If yes to the above ... are there any lights on at all ... sewing light, display backlight ?
If it's completely dead, it's most likely the power supply 'L'-print which is a separate module screwed into the back of the machine below the spool holders. Your best bet is to get the machine checked-out by a Bernina service agent.
Posted on Oct 30, 2011
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
Bernina activa 210/how do i switch reverse sewing back to statight stitch
Perhaps the manual would be helpful:
BERNINA activa 210 Support BERNINA
You may want to download and keep this manual. A lot of manuals for older Berninas are no longer available.
Dec 15, 2013 | Bernina Activa 130
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
Oct 28, 2011 | Bernina Activa 130
My Bernina Activa 240 won't turn on. I checked the outlets and they are fine. I even plugged it into different outlets hoping for something to work and it didn't. Can I take it apart and fix it...
Jun 02, 2011 | Bernina Activa 140
Sewing Machines Logo
519 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
