Question about Canon Imagepress C1 Color Copier, Printer,q2 Print, Aa2 Finisher, Low Meter
Streaks in prints - Canon Imagepress C1 Color Copier, Printer,q2 Print, Aa2 Finisher, Low Meter
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Vista for canon pixma mp140
Here's the solution from Canon USA:
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Canon Imagepress C1 Color Copier, Printer,q2 Print, Aa2 Finisher, Low Meter Logo
26 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
