Question about Lexmark Office Equipment & Supplies
Lexmark S406 not printing color
I don't know why my printer, now, even with new ink cartridges will not print color or text.
  • 6 Answers
SOURCE: Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Posted on Jan 31, 2007
bluenadas
  • 203 Answers
SOURCE: Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Posted on Jun 08, 2007
agent1463
Good day sir, My Lexmark z35 color printer doesnt work. I already tried to use the printer settings properly but still failed to print the color ink. Only black ink in printer is printing. Im still hoping that you have any solution for this. pls.. help. thanks!
Posted on Jun 16, 2007
SOURCE: Printer doesn't print even with new ink cartridges.
Remember to remove the Seal Tape from the Top of the New Ink Cartridge as well as from the Bottom ! !
If a “Head Cleaning” cycle makes the Test Pattern worse, STOP.
Disconnect the Printer from the Computer.
Press the “Cartridge Change” button for ~ 3 Seconds.
When the Ink Cartridge Carriage travels to the Changing Position PULL THE POWER PLUG (NOT the “OFF” Switch). The Ink Cartridge Carriage should now Slide Freely on the Rail as long as it isn’t pushed to the Right so that it goes under the shelf to the “Homed and Locked” Position.
Fold up a Paper Towel (About 1 Sheet) so that its final width is about the same as the width of the gutter under the Print Head on the Carriage and so that it is thick enough when folded to contact and lightly press on the Print Head.
Saturate the folded Paper Towel with ~ 70% Isopropyl Alcohol and lay it in the Gutter.
Manually slide the Carriage and Print Head Over the wet Paper Towel. A slight amount of drag should be experienced if the thickness of the paper towel folds is Correct.
Let the Print Heads rest on the Saturated Paper Towels for a few Minutes or Hours. Too long a Treatment may pull out all of the Cartridge’s Ink: Check the Paper Towel Frequently to Assess if Ink is Capillarying out onto the Towel.
When the Treatment appears Successful remove the Paper Towel and Clean Up and plug the Printer power back in.
Run a Test Pattern via the Computer Connection WITHOUT first running the Head Cleaning Utility.
If the pattern isn’t OK, Try Running the Head Cleaning Utility to see if it makes it Better or Worse.
If Worse, Repeat the Alcohol Paper Towel Treatment: The Paper Towel may be Gently Pulled back and forth under the Print Heads to wipe them off.
Posted on Mar 31, 2008
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
DO THIS AS FINAL REFUGE
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
Posted on May 16, 2008
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
My Impact s305 printer has full ink cartridges-I even just replaced one a few minutes ago and the color ink won't print out-only the black will. I've already tried to reset factory settings. It...
Lexmark recognizes that some of our inkjet all-in-one customers may be experiencing issues with their print quality. We take our customer user experience very seriously, and we strive to ensure that each time a customer prints using a Lexmark device the page is crisp, clear and up to the highest standards.
However, if your device is displaying a 'printhead error' on the hardware and/or you are suddenly experiencing a print quality issue, please contact the Lexmark Technical Support Center at 1-800-539-6275 or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Aug 10, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Lexmark Pro 705 won't let me print after refilled
If you refill the regular lexmark 100 ink cartridges, you will not be able to use it because there is a rfid chip that track the ink usage. you will need to buy the 100a type which will let you print if the ink level is empty. since you have refill the 100 ink cartridge, you can swap the 100a chip to your 100 cartridge.
Apr 19, 2010 | Lexmark X4650 InkJet Printer
Lexmark printer cannot print with black ink only, why?
Hello, Char.
Most inkjet printers are designed to require both black and color cartridges, even though you may be printing in black, only.
Please let me know if I have not understood your question.
Hope this helps.
Dec 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
I have a Lexmark x1100 Series printer and cannot print anything now. This printer has been working but it stopped printing. Do not have the CD.
Need more info. Any error messages? Did it just stop pumping ink on paper. Are you trying to print black text or color picture? If no error, your cartridges may be empty. If black text does not work, try color picture. Usually one cartridge goes empty and the other still has ink. If color pic prints replace black cartridge. If neither black or color prints at all, it may be a toasted printhead
If you need to reinstall the software, uninstall it, then go to lexmark.com and get new drivers from their site. RESTART COMPUTER! Reinstall from the downloaded file.
If all the above fail to make it work, it is hosed, shop for new printer.
Dec 09, 2008 | Lexmark Office Equipment & Supplies
Colored Ink problem
Jun 08, 2007 | Lexmark Color Z35 InkJet
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
