Question about Crosman C11 CO2 BB Gun - 0.177 Caliber
Can't load bbs it won't fire bbs - Crosman C11 CO2 BB Gun - 0.177 Caliber
My BBs roll out of the barrel when cocking gun, what is procedure to load, ****, and fire? Model 188
On all bb guns I have seen the bb in the breech is held there by a rubber ring until it is time to fire.
If the bb's are falling out maybe the ring is worn or missing.
Mar 15, 2015 | Cars & Trucks
Loaded w/bbs fresh gas cylinderwill not fire or does notshoot BB?
it sounds like you have a bb jammed in it
Oct 24, 2013 | Toys
Loading mechinizm does not pick up a bb and load for fireing. Plenty in there; can hear them rattle.
The bolt should be magnetized to catch a bb. Some rifle have to load a magazine upside down to get the bbs lined up on the top with a small thumb switch. Then when you bring the bolt back the mag pickup on the bolt should take a bb from the top and load into the chamber.
Oct 15, 2013 | Crosman Optics
The BBs won't come out or shoot.its a crosman MCSR01 air gun
Seal leak in the air chamber.Need new seals
Mar 15, 2013 | Optics
The BBs won't come.the gun won't it's a MCSR01 crosman air gun
With magazine out, what happens after cocking, should get a gush of air, if nothing, spring not latching, or seal leaking badly, have you adjusted trigger, to fine with a spring type, will not latch, so no pressure, can you feel anything happening, nothing at all spring latch, can you feel the pressure of the spring when you cook it.
Stopped firing. Battery and fuse are fine.
The part that feed the bbs most be broken. or your mag is broken. dose its work in other modes?
Feb 08, 2013 | Crosman CM4 Marine Rifle Electric Airsoft...
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
I am doing a tune up and cant find the ignition control module in the engine compartment
It won't be in the engine compartment. It is too hot and too wet in there.
My guess would be behind the panel to the right of the passenger's feet, or under the dash behind the glove box.
The best place to ask questions regarding a 740 is the RWD section of the Brickboard bbs. http://www.brickboard.com/RWD/
Jun 26, 2011 | 1985 Volvo 740
I have a Daisy CO2 200 pistol and it won't fire the bb's. Wasn't there some process for moving the bb's around to be fired? Also, the slide on the left side of the pistol doesn't do anything, what was it...
After loading BBs in the rear of the gun (by moving the slide cover and inserting BBs one at a time), push the slide upward with your thumb while pointing the muzzle of the pistol in the air and rotate pistol--this should charge the magazine.
Also, change the CO2 cartridge. They will leak out depending on the seals condition. Remove the left grip and turn the lanyard screw down to access the cartridge. While the grip is open, add a drop or two of 3-in-1 oil into the oil well on the bottom of the receiver.
Nov 01, 2009 | Sport & Outdoor - Others
Crosman C11 CO2 BB Gun - 0.177 Caliber Logo
143 people viewed this question
Top Crosman Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Crosman Tool and Hardware - Other Expert? Answer questions, earn points and help others
