My tv powers on and off. When you unlpug it and plug it back up it powers on. and it will power on and off sometimes five or six times in a row and then it might stay on for a minute and then go off. sometime it might even stay on for ten or minutes before powering off. I just need a little help
all cables are fine plug is good. It has to be internal. Sometimes the power button will not even work.all cables are fine plug is good. It has to be internal. Sometimes the power button will not even work.
You can't post conmments that contain an email address.
An expert that gotĀ 5 achievements.
An expert whose answer gotĀ voted for 20 times.
Expert
Re: powering on and off
I must say this is a wierd problem here.
First of all, make sure that the T.V. has enough space, and the cables arent layed on each other, give each cable its space.
Now, try to check the main T.V. cable, is it strongly plugged in? because it should be, might be that your cable is weak and gets loose sometimes, so try to plug it in in a strong way.
Keep me informed.
Why didnt you just say so? You should go back to the store and complain! it'll cost you alot to repair this, so you'd better get a new one. Hope you have your warranty.Why didnt you just say so?
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
You have to press and hold the power button down sometimes for as long as five or six seconds. If you've done that and it still isn't coming on, try doing it in a dark room. If the screen brightness somehow got turned all the way down, it might be starting up but you might not be able to see it under normal daylight. If this doesn't work either, I suspect a bad battery or battery connection.
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TV will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone. Good Luck Ed Pinero
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, If you need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help to solve the problem
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
not the Wii itself, so power to the AC adapter needs to be cut off.
Unlpug it from
etc...anything, this will happen. You plug it back in, the power comes on, but it appears dead. The problem is with the AC adapter,
not the Wii itself.
Unlpug it from
or 10 minutes, the red led on the front should be lit up, and it should work.
I have the same problem. After power on I just get a blue screen and no sound.
I can get a piture and sound if i do the following.
Leave the TV on for a minute or two then unplug the power while still on. Plug back in and power on. I begin to get sound, repeat and then I get a picture for a few moments then blue again. Repeat and then I get constant picture with defunct colors. I then use the remote to power off and back on an color corrects. sometimes have to repeat this as well. Sometimes it takes unplugging, replugging, and powering on up to five times before i can sit down to watch tv.
This
is a common problem with the Wii. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. It happens
almost every time there is a power surge or the power goes out, etc.
Even
if it's hooked up to a surge protector, this happens. Power comes back
on, but the Wii appears dead. It won't turn on, and the LED indicators
won't light. If there was a power surge, or the power went
out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset.
the adapter.
and leave it unplugged for 5 or 10minutes. This will kill power to the
adapter back into the outlet after 10 minutes, the red led on the front
should be lit up.
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes) -Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each) -Wait one full minute and plug TV in and press power on
You might want to unlpug the powercord for the night, then plug it back in the next morning. Some times that can help reset things.
If that still doesnt do the trick, you might have a faulty power cord. If it does this with every source you hook up to your TV then that would be a sign that its something in the set vs. your external source.
