Question about Dryers
Fridigaire dryer makes a loud whining noise
Usually stops after the dryer gets warmed up
  • Mark Egan May 11, 2010
    Sounds like a bearing i slacking lubricant somewhere in the dryer. These are not usually user serviceable, but you can remove the service panel and listen while the dryer runs to determine where the noise comes from. Then reply back, with your specific make and model number, and I can further direction/instruction.
  • 979 Answers
This is probably what the above comment says. You may can spray some WD40 on the spindle or axle that holds the drum in place. I have found occasion where this has solved the problem.
Posted on Jan 27, 2009
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
My dryer is making loud noise and after it gets warmed u it stops. I have replaced felt inside
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 07, 2010 | Frigidaire Dryers
My dryer's model #FDE546NB51 & the serial number is #XD5396691 It's making a loud whining noise .
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 06, 2010 | Frigidaire Dryers
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
Vfr 400 nc24 whining noise when engine is reved
The loud whining noise is just normal for vfr 400 because it is gear driven cam.. As you reach 5000rpm up, the bike's electrics try to misfire the plugs so it would act as a speed limiter (180kph).. You have to bypass the sensor at the speedo..
Sep 28, 2009 | 1988 Honda VFR 400 R NC24
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
Dryer makes noise and vibrates when starting and stopping
Most likely it is the bad blower wheel. The clothes seems hotter than normal oh yeah bad blower wheel.
May 19, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
Dryers Logo
123 people viewed this question
Top Dryers Experts
