Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi HDTV Flashing green timer light
  • 1 more comment
  • instag8r67 Feb 03, 2009
    I have the same issue. Had it before and it was the timer. I was out of town on business and TV would come on at 10 or 11PM while every one was asleep. I had to wait for it to come on to fix it. This did not work for me. So my question is....can you over-ride the timer once it is set and power button nor the reset does not respond prior to the timer turning it on?!
  • instag8r67 May 11, 2010
    Menu button did not help!....Thanks
    Should you unplug while holding "MENU"?
  • 68 Answers
MOST LIKELY DM BOARD IS GOING OUT.
Posted on Feb 03, 2009
  • 33 Answers
Press and hold menu button for 8 sec, then unplug for 1 minute. Plug back in and 1 minute later it will pop up for you.
Posted on Jan 27, 2009
  • Ben Wine Feb 03, 2009
    Hold down menu button for 8sec, then let go and and unplug.
3 Suggested Answers
  • 239 Answers
SOURCE: Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
Posted on Mar 06, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 29, 2009
Hdtv flashing green light for timer tv wont turn on
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
Mar 20, 2013 | Mitsubishi LT55164 Unisen Medallion 55...
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Same Green Light flashing!
The timer light flashing usually means that the bulb needs to be replaced.
Jul 25, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
276 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
