Lg 32lh2000, my tv just stopped working all of a sudden when I went to turn it on, not sure if something has blown on the circuit board but the power lead makes a crackling noise when I take it out of the back of the tv, any suggestions?
SOURCE: crackling noise only lg 42px5d
you fucked it
Posted on Jul 31, 2008
  • 298 Answers
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Posted on Dec 29, 2008
  • 35 Answers
SOURCE: My samsung plasma suddenly made clicking noises and tuned off
I wish to tell the world about the simple cheap fix for your plasma! . Please let me know if I helped. I have a 50" Plasma that deicded after a year it didn't want to turn on anymore. It just blinked red LED. Which made me see red! It took me a year to find this inexpesive fix I hope this information will be helpful to you.... These are spendy items and none of us were thinking that after a year (seems like a scam to me) the TV just won't turn on anymore.... Then they say your no longer covered under warranty or you are and they send you to some repair shop 1-2 hours away and always and I mean always tells you the part is on back order.
Lukster is right it is a power supply problem. However you don't need a new board nor do you need to pay someone a ridiculouse abount of money to fix this. I fixed mine for 40 cents.
You more than likey have bad capacitors.
Unplug the TV from power. Remove the back cover. (some models require a star srewdriver) You power supply board is right in the center. A bad cap is bulgded or raised. A good one is flat. caps have an X on the top of them. More than likely you will see a bulding or just straight raised edges on the X on the top of the caps. Cap 3300uf 10v is the ones you are looking for. Once you find them replace them with 3300uf 16v caps. If one cap is not raised replace it anyway. These caps need to be a higher voltage that why the tend to pop. 16V is plenty, don't go any higher in voltage than that.
The caps need to be soldered on. You have 2 options do it yourself or unplug all the wire harness from the board then unscrew the board take your power board (dont forget your new caps) down to a pc repair or tv repair and have them solder them on for you. It will take less than 10 minutes. I do recommend putting the board in an anti static bag. You can buy these caps at radio shack or buy them on ebay.
After you get it repaired replace your board plug all power supply wire harness back onto the board (I recommend numbering the wires as you remove them), replace the back panel cover. Plug her in and fire her up. and BAM it works. then turn it on and off a few times in complete amazement at how simple and inexspensive this was to do. Then get angry cause your repeated calls to tech support was wasted breath.
Semper Fi
Posted on Feb 07, 2009
tvservice306
  • 458 Answers
SOURCE: lcd LG television...sound suddenly stopped. no
replaced main board
Posted on Aug 18, 2009
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
Posted on Oct 28, 2009
My Olevia 232 s12 tv seem to have blown out, my daughter used a hair dryer while the air was on the electricity stop. used the circuit breaker everything came back on except the tv. fix it or toss it.
If your comfortable doing it take the back off and check the main power fuse on the power supply, replace it if blown but it may blow again, if it does the rectifier in the hot side of the PS board is shorted and needs replacing or it will need a new power supply board...Good luck!
Jun 29, 2017 | Olevia Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
Electric utilities went down only one TV came up
Do the dummy checks first. Check to see if the breaker for the one that wont turn on did not pop. Make sure it is not on a GFI circuit that popped. Final test would be to plug it in to a known working outlet. If all that proves to not help then I would say you have a blown power board. Fixable, but you will have to take the tv apart to get the part and part number.
Apr 18, 2016 | LG Televison & Video
LG 55LX6500 55 inch LED TV display gone, but sound works.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Jan 02, 2016 | LG Televison & Video
Was watching my samsung LN55C630 TV and all of a sudden it just went dead. nlo picture and no sound,also the power light went out thats normally on when the tv is off.
Check the circuit breaker first for power to the outlet it is plugged into. If it is in a power strip then make sure that the reset is hit on that. I sounds like you had a line surge for some reason. If all else fails there is a fuse on the power board in the TV. Check to see if that is blown. If not check for black burn marks on the power supply board. Could have blown that altogether.
Mar 05, 2014 | Samsung Televison & Video
My lg 32lh2000 switches on shows logo then turns of please help
That problem is on main board if you don't have sounds but if you have sounds the T-Con board is faulty not main board..
Feb 23, 2012 | LG 32LH2000 32 in. HDTV-Ready LCD TV
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Gateway GWT-P42M303 screen problem
the 15v is shorted to the ysus board and probably one of the two big heat sinks with the number 4921QP1002B is the cause. If you don't repair it can I have it for parts?
Mar 30, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
