Question about Lite On (SOHC-5232K) (SOHC-5232K-BULK) CD-RW/DVD-ROM (Combo) Burner
CD drive Missing
When i try to eject the cd from my driver it will no longer eject. I have a compaq computer running windows Vista. Now it isn't even allowing me to access the cd that i know is in there. What is going on?
  • 46 Answers
Take a paper clip and unfold it. Insert it into the pinhole thats on the front of the drive. This should FixYa!
Posted on Jan 27, 2009
My daughter has a C551 NR running vista. The CD\DVD Rom stop working in Vista so I used an external CD drive to install Windows 7, works great. . I ordered a new drive upon HP recommendation 435778-001....
should recognize the cd rom /dvd unit automatically
lower picture is of the c300 cd unit
anything look different from the original ............lowest picture
CRX880A Compaq Presario C305LA C508US C551NR Optical Combo Drive CD-RW DVD- ROM
Apr 17, 2017 | Compaq Creative Sound Blaster PCI 128...
My computer will not load windows, how do I remove a CD from my Gateway GZ7112
there should be a tiny hole under the drive door for ejecting the drive manually by pushing a small enough metal object in it such as a small screw driver. This will eject the cd. Thanks, Cody
Sep 13, 2012 | Computers & Internet
Tsstcorp cddvdw ts l633p error code 19
Code 19 means there is a driver conflict such as two devices trying to use the same resources.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
Normally the above will fix that issue if not work your way down through these even if you have done
them before.
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/314060 - a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Hope these help.
Jun 14, 2012 | Computers & Internet
DVD/CD don't work any more, not recognized by the computer. Driver is missing? Windows Vista
Try to go this website gur.in, click registry tweaks and on the Tech domain registry look for Restore missing CD drive. Just run it and allow. After that restart the laptop. Check if CD/DVD drive is back and test a disc.
Hope it works!
Mar 12, 2011 | Computers & Internet
Cd drive wont eject
Try ejecting it through "My Computer". Right click on the drive and select "eject". If you can't locate the drive, then it's probably missing the driver.
Nov 25, 2010 | Sony VAIO VGN-NS240E/W Notebook
Cd/dvd driver
Hi
cd/dvd drive doesn't require drivers at all, the drivers come with windows and if you are missing or corrupt drivers on the cd / dvd drive then
try this:
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
if that doesn't solve the problem then use the windows cd to install windows to the computer again and start over or use the restore cds to restore the computer.
Apr 11, 2009 | Acer Aspire 4720 Notebook
Hard drive driver problem
It is possible that your hard drive is a SATA and therefore not readily readable by 98, XP but surprised not even by Vista. In any case, since you would still prefer to run XP (due to other software compatibility issues), pls press F6 when prompted by the XP installer. Additionally, you would need to have ready in a floppy the appropriate SATA drivers for your motherboard. They maybe downloaded from the motherboard manufacturer's website or possibly in the installer/driver CD that came with the PC.
Other than the above, it is also possible that you may have some issues with the availability of XP drivers for the other devices for that computer specially if it is branded.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
CD rom drive not working
sounds like it's gone home early. replacement will do the trick..
Mar 06, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Ntldr is missing
seems your MBR is damage. but you can repair it if only you can boot in windows cd and entering in the recovery console.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.    At the command prompt, type this commands one at a time.
FIXMBR  C:
FIXBOOT  C:
COPY [CDDRIVE]:\I386\NTLDR  C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM  C:\
BOOTCFG  /rebuild
6.    To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
no warranty...you use on your own risk :)
Oct 27, 2007 | Compaq Presario sr1111nx 2.53GHz Celeron...
Compaq Presario V2000
somthing thats worth trying is going into my computer, right click on the cdrom drive and click eject if it works that way then its software thats stopping it from ejecting, if it still dont work take a paperclip and push it in the small hole in the cdrom drive and it will pop out its only a temporary thing but it works to get the cd out.. All the Best John
Mar 07, 2007 | Compaq Presario 1200,1600 (297657-001)...
Lite On (SOHC-5232K) (SOHC-5232K-BULK) CD-RW/DVD-ROM (Combo) Burner Logo
75 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
