Question about Lenovo ThinkPad T61 Notebook
Unable to start up/unlock computer
Bought used laptop @ swap meet. When turned on, screen displays a computer icon with a "lock" icon next to it. Can't get out of this screen.
  • Lenovo Master
  • 32,281 Answers
This laptop has a power on password. There are no backdoor passwords available and removing in BIOS battery won't fix this problem because the password is stored on an EEPROM chip.
I'm not sure which EEPROM chip is used in you model laptop, but if it is the Atmel 24RF08 chip then you can hack into this to recover the password. For information on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Posted on Jan 29, 2009
Once I turn the computer on it only shows a blank screen. I am able to see the mouse arrow move but I am unable to get to my desktop or anything else. What do I do?
If you can see the mouse arrow, the display adapter is working. Try right clicking on the desktop. If you get a popup display, select the VIEW option, and another popup should appear next to it. Look at the bottom of the list and ensure that the "show desktop icons" selection is checked. If not, click on it and see if the icons return.
Oct 03, 2015 | Gateway NE56R10u Laptop Intel Celeron...
Phone is locked. How do I unlock it?
With front of phone facing you. On the left side of the phone you will see two grey slim inline buttons, and or, keys. The top button, and or, first key is the UP/DOWN VOLUME key. The bottom button, and or, second key is the LOCK key.
(1) To UNLOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD UNLOCKED". You are now done.
(2) To RE-LOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD LOCKED". You are now done.
In Addition:
(3) To set AUTO-LOCK on the phone.
GOTO the MENU key. Located on the top left of the keypad on the front of the phone. The LARGE WHITE HORIZONTAL BAR directly under the word MENU on the screen readout. PRESS-IT ONCE. You now SEE the PREPAID ICON.
Next, locate the OK key, top center on the keypad. Directly below the middle of the screen readout.
Next, locate the UP-ARROW key directly above the OK key. By using the OK key PRESS-IT ONCE. Now you see the SETTINGS ICON.
Next, by using the OK key, PRESS-IT ONCE. Now you are in SETTINGS.
Next, locate the DOWN-ARROW key. Located directly below the OK key. PRESS-IT ONCE. PHONE SETTINGS should now be highlighted for you.
Next, by using the OK key, PRESS-IT ONCE. You are now in PHONE SETTINGS.
Next, GOTO the UP-ARROW, PRESS-IT ONCE. AUTO KEYPAD LOCK should now be highlighted for you.
Next, by using the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the OK on the screen read out). PRESS-IT ONCE. You are now in AUTO KEYPAD LOCK settings.
Next, by using the UP or DOWN ARROWS, GOTO the amount of minutes that you would like to set your phone to auto lock for.
Next, GOTO the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the screen read out). PRESS-IT ONCE. Your screen read out will now display, "DONE"
Your phone is now set to AUTO-LOCK when your phone has been at rest for the amount of minutes that you have selected.
If you would like your phone to lock sooner in order to place it in case, pocket, or purse. Simply refer to (2).
Jan 31, 2014 | Alcatel Tracfone A382 BIG EASY No-Contract...
How to unlock a jcv s1465 screen
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Feb 26, 2013 | Insignia Televison & Video
How to turn off clock on jvc tv
Sep 06, 2012 | JVC Televison & Video
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
When i start Lenovo thinkpad T400, i get to see a lock symbol with blank screen
Hi sundar1968,
I see that your Thinkpad T400 machine is locked and you are unable to make use of the machine.
to be able to unlock the machine power the system on once turned ON you will see a Lock icon on the center of the screen just press and hold down the FN key for at least 5-7 seconds or if possible untill the lock icons shows that it is unlocked.
This should help you with your concern.
Have a nice day,
mvincentc
May 11, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
My F22 monitor had been appear OSD locked and i don't know how to solve it. Some buddy please help me!!!
important notes
1. what is displayed on the monitor comes from the system unit
2. possible features that could be displayed on the monitor are screen savers or splash screens
3. attempting to log on a computer with a screen saver passcode could lock the system by displaying the word locked requiring unlocking
procedure of unlocking a passcode
1.Once the system locks, would require to reset the password.
2. another function could be displayed on next to the lock icon prompting unlock or reset
3. in the absence of a display of unlocking the password, continue to enter the wrong password and hiting the logon button in a space provided next to the unlock icon prompt
4. severall attempts would prompt for a reset functionality.
5. at which instance would display a password hint of what has been locked.
6. the password hint provided must be guessed correctly to allow a reset functionality.
7. once hint provided allows for reset would prompt the user to create a new password
8. create a password with a hint as a key to reseting any future locked screens.
9. the screen could be operated without a password for an alternative, only made possible during after unlocking the locked screen. instead of creating a new password and hint, choose to disable screen savers altogether.
Dec 06, 2010 | AOC F22 Monitor
How to lock a keyboard
  1. Press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it. In some versions of Windows you will need to get to the option by pressing the left shift key five times rapidly.
  2. Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
  3. Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
  4. Lock your workstation. Press Ctrl + Alt + Del. A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer."
  5. Lock your workstation using the keyboard. Press the Windows key and the L key at the same time. This will lock the computer. To unlock press the combination again.
Aug 22, 2010 | Dell Vostro 1015 Laptop Computer (Intel...
Computer can not find bluetooth device printer HP Photosmart C
Step one: Install the softwareRe-install the software so that the appropriate choices can be made during the installation to resolve the issue.
  1. Insert the printer software CD in the CD-ROM drive of the computer. The software installation starts automatically.
    NOTE: If the software installation does not start automatically, click theStart (c00845897.gif ) icon. In the Start Search text box located above theStart (c00845897.gif ) icon, type D:\setup.exe , where D is the letter of the CD-ROM drive, and then press Enter .
  2. On the User Account Control window, click Continue .
  3. Follow the instructions that display on the screen to install the software.
    NOTE: If the User Account Control window displays during the installation, click Continue .
  4. When prompted to choose the connection type, select Directly to this computer using a USB cable and then click Next .
  5. On the Connect Your Device Now window, select If you are unable to connect your device now, click this box and then click Next to finish installing the software. You can connect your device later.
  6. Click Next .
  7. Follow the instructions that display on the screen to complete the software installation.
Step two
AND STEP THREE
GO TO URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00845953&lc=en&dlc=en&cc=us&product=447858
Dec 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
Unable to unlock screen
The A with a lock icon is the symbol for the capslock. maybe the reason why you cannot log back on is that it's not accepting your password because you have the caps lock on.
Oct 09, 2008 | Acer Aspire 5315 Notebook
Lenovo ThinkPad T61 Notebook Logo
2,222 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
