Question about HP OfficeJet 4215 All-In-One InkJet Printer
Copies My machine won't make copies. At first the printing was sketchy, then the page was blank. There was no indication of low cartridges. Is it true that if you have to replace the ink cartridge you have to replace both????? My #4215 is not hooked up to my computer. I only use it to fax and make copies. Thanks, B.
    Genius:
  • 2,120 Answers
It's true. All cartridges are used for each copy. Black or color. only use GENUINE HP carts.
Posted on Jan 28, 2009
I haven't used my printer in a while so when I try to print something the pages come out blank, but my ink cartridges are full. What could the problem be?
Have you tried putting it through the cleaning cycle found in the list of options on the screen? Also, does the page come out blank for copies as well as printing?
Jul 06, 2015 | Brother MFC - 255CW Fax / Copier / Printer...
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
Xerox 4118
That isnt unusual. The 8000 pages is for a page with 5 percent coverage area, or a rather short letter.
the 3600 to 4000 pages is not out of the ordinary for that machine, Although the xerox brand may work better, although not more copies, if you run pages with more than 5 percent of the page printed, that is about right.
Also there is no chip on a 4118 cartridge. The toner is monitored by a sensor and window in the middle of the cartridge. It shines light through the cartridge, and when the cartridge is empty the light actuates a light activated sensor.
it is not an efficient machine.
Dec 15, 2009 | Xerox WorkCentre M15i Laser Printer
Removed paper jam and now copies are blank.
Drum Memory
Make about 5 to 10 prints; then, leave the machine in the office environment (normal temperature/humidity conditions)
* This symptom is noticeable in a low temperature/ humidity environment, and is absent under normal environmental conditions.
* This symptom occurs in keeping with the primary charging roller rotation (38 mm).
Sep 13, 2009 | Canon imageCLASS D780 All-In-One Laser...
Printing quality problem
HELLO! IF YOU ARE USING A GENERIC DRUM OR TONER, YOU WILL HAVE COPY QUALITY PROBLEMS
Jan 14, 2009 | Brother IntelliFax-2820 Laser Fax
Blank copies
Blank copies are related to a empty or bad cartridges - Try cleaning your cartridges or replace them.
Try printing differents documents and see what happen.
Check yor printer cables
Check your printing settings
Check if your printer is "ready"
Check the connection between your computer and your printer.
Sep 06, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Blank trace appears on printed copy
replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Jan 07, 2008 | HP LaserJet 1020 Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
