Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Wont come on
It says permanent hold and wont come on
  • Dale Koehn
    Dale Koehn May 11, 2010
    have you tried pushing the hold button again ? Have you tried removing the batteries ? let me know what if anything the furnace is doing after you try these two things, thanks,
    mr.grzz
    New Friend:
  • 92 Answers
Push run program button
Posted on Feb 05, 2009
After having Matrix optismooth treatment done on my hair it won't hold hair color. Every time I shampoo I can see the color washing out. I am using permanent color? Why is this happening?
There are a lot of reasons that hair wont hold dye. One is what conditioner you are using before the dye. Some conditioners have silicon in them and coat the hair to the point that it wont allow any dye to penetrate. Another is the brand of dye, some dye is better than others, third is your hair type, this can be checked by a professional but some hair types respond to dye better than others and you have to keep trying to find a brand that works best for you,
Jul 09, 2016 | Matrix Health & Beauty
Engine sin appearing permanently also hold alarm light blinking what might be the issue
There is a problem with the ECU and needs to be cleared and reset by a workshop that has a diagnostic machine
Apr 13, 2014 | 2006 Chevrolet Aveo
The clucth nut keeps comeing lose and the clucth wont work it hold the clucth basket in plase
Thread lock will fix that. Not a permanent lock but Loctite Threadlock.
Feb 27, 2011 | 2008 kawasaki Ninja 250R
If we enter a specific temp while using the hold button will it keep that temp without doing any additional programming?
If you set a permanent hold yes otherwise it will revert back to the program on the next cycle change. Press and hold "hold" and see if a number of days or permanent option comes up.
Feb 25, 2011 | Heating & Cooling
Honeywell TH8320U1008
simply push cancel. That clears the hold feature.
Pushing hold once gets - permanent hold.
Pushing hold twice gets - days of permanent hold. So you can set it if you are going away on a temp and at the end of the days it goes back to normal operation.
Jul 21, 2009 | Heating & Cooling
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
May 16, 2009 | Honeywell Programmable Thermostat Heater
HP laserjet 3330 Permanent Storage Init.
Switch of the printer press and hold down menu and cancel button turn on the printer keep holding these two buttons and turn on the printer.
As soon as printer display shows permanent storage init. release both the button.
May 11, 2009 | HP LaserJet 3330 All-In-One Printer
Motorola HS820
the always on light mens that it is in pairing mode and wont go out until it has paired with a phone, if you wish to turn it off, press and hold for 3 seconds, it will then flash 3 times and then go off. Try pairing again by pressing and holding the button until the light stays on.
Jul 10, 2007 | Motorola Mobility HS820 Consumer Headset
Heating & Cooling Logo
270 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
