Phillips flat screen 50pf9631d137 won't turn on and is flashing a code of six flashes
5 Suggested Answers
SOURCE: Phillips flat screen won't work
First, eliminate the possibility that the power cord, itself, is not faulty. Try another power cord from, say, your computer, or something else with the same type of power cord. This is often overlooked
Posted on Jan 19, 2009
  • 5 Answers
SOURCE: Phillips Flat TV Model 20pf4121\105 (Flashing green led)
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Posted on Sep 22, 2009
electrolitic capacitors 1000mf /10 v in pover unit
Posted on Jan 02, 2010
SOURCE: my phillips flat tv won't turn on?
My 42" Philips TV will start, then shut down. I need to hold the power button until it powers all the way on, even so, it will still shut down sometimes. Usually, after 2 or 3 times of this power on sequence, it will finally stay on. I noticed, when the power on fails, the picture is pixelated. Any guess to a solution.
Posted on Jul 07, 2012
My Phillips model number 27PT6441/37 tv doesnt come on when u push power. Instead power indicator flashes a total of six times. 2 flashes,then 3 flashes,and then 1 flash. What does this indicate?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jan 04, 2017 | Televison & Video
Why my phillips flat tv turns of and the red light flashes six times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Counting of the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jul 31, 2014 | Peerless PLP-PH42HD Bracket for 42"...
Flashing six setting modes and won't turn off.
DONOT START MACHIN BUT BECOM FULL WATER AND ERROR OE
Apr 04, 2013 | Dishwashers
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Set won't turn on, 10 red flashing lights
This is an error code and depending on brand/model number can have a number of meanings---
You can GOOGLE the model number with "error codes" etc to get an idea of what likely your error code means.
Mar 19, 2012 | Televison & Video
Have a Phillips RC144 5302 Remote that is not working with a LG 372D Flat screen TV
Try these codes.
0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 08, 2012 | Televison & Video
Tv turns off and I get a red flashing light on philips flat tv model 42PF7320A/37
After looking through the user manual I could not find any error codes to diagnose your problem. I suggest calling Phillips Customer Support at 1-888-PHILLIPS.
Sep 30, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
My phillips 42" HD Flat screen won't turn on
I switched the power cord with the one to my desktop monitor and it worked ..i noticed the end going into the TV had some discolor to it ..I put the one from the TV into my desktop monitor ..and that worked too..must of been a shortage of power from the cord to the TV?
Jun 11, 2009 | Insignia 42" LCD Flat-Panel HDTV
I have a phillips 42' plazma and for some reason the screen won't turn on/ Red light keeps on blinking, pleas help
this is an error code that shuts the unit down and places it into a protection mode -- you need to call the customer support line at philips and they will tell you exactly what code the red light is flashing -- what is the flash ? the power board on these television is real cheap and needs to be replaced ----
Feb 02, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
