Question about Apple iBook Mac Notebook
Cannot log in "CORRECT" password to connect to a wireless system
I am using the correct password. I can connect to other wireless systems that do not require a password.
  • mechainiac55 Feb 03, 2009
    LOL.... I must have been really tired when I read that...
    I am having problems logging on to wireless at an RV park that has wireless. This is only with my ibook, the other laptop logs in with the given password. Should be the same for any/all...
  • M Norwood May 11, 2010
    Whose Wireless Network are you attempting to log onto? Yours/Your Friends/Your Telecommuncations Companies/etc.
  • 55 Answers
Chances are you are using OS X 10.4.11 or lower, when you connect with that version of the OS, the default connection to a wireless network is WEP, but if the network requires WPA or something else you have to manually select it, then put the password in.
Posted on Feb 22, 2009
Forgotten password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 15, 2011 | D-Link DIR-615 Wireless Router
I couldn't log in to yahoo messenger
Good Day Downtown!
There are different possibility while you can not log in to Yahoo Messenger right now.
Better check if your internet connection is stable. You can also disable the Firewall setting on your system, most of the time Firewall blocks the connection of Yahoo Messenger especially when connection is wireless.
Also, make sure you type the user id and password correctly. check for spelling and capital letters when you type it.
If you can upgrade the Internet Explorer in your system, that would help in Yahoo connection issues. Cause Yahoo products rely its connection from Windows Internet Explorer.
Please go to http://icantsignintoyahoomessenger........
and take some time to read it cause this will helps in your connection issues.
Good Luck Downtown!
Hope you will comeback later after you have log in successfully with Yahoo Messenger.
Jun 11, 2011 | Computers & Internet
I want to find the pin for linksys router to give to house guest. can't find it on router
when you say pin do you mean the encryption key? and if so what operating system is on the computers in which are currently connected to wirelessly ? and did you try going to 192.168.1.1 and typing in your admin info? (default is usually admin for name and no password or password as password) and going to wireless then security and you should see something written next to the generate option and hit generate and that shall be hte key
Jun 02, 2011 | Linksys Wireless-G WRT54G Router
I have a nrtwork konektion all I nead is to fine the password and use the internet line
Are you using a wireless router to connect to the internet?
If you have forgotten what your connection to router's password is, I suggest to reset the router by locating the reset hole. Just push it with an unfolded paper clip for about 10 seconds and it will be back to default settings which is no password.
Hope this helps.
Apr 02, 2011 | Computers & Internet
My Netgear adsl router is not getting connected to Internet in pppOe mode ..
POPE configuration is logs into your ADSL system and connects to your ISP provider server to link , so one of the reason why it dosent is due to either password and username not correct. Log unto IP address of your Router and go to WAN configuration , Check your username and password and reset to the initial password and username your ISP provider gave you , when you signed up with them. Then apply changes , off your router for 1 min and then power it , then wait for the ADSL light on the router to be stable , connect to the IP address of your router again and "Volla" , it should be fine , if not , contact your ISP provider....
Oct 07, 2010 | NetGear DG834G 802.11G Wireless ADSL...
Need to change password as it bein hacked
Log in using a wired connection to the router (probably 192.168.0.1 but if you right click on your conection and check the details it will be the gateway address) and go into the security settings and select the securilty system you want WEP or WPA. You will need to set up all the wireless devices devices to the same system
Apr 04, 2010 | NetGear WGR614 Wireless Router
I have LINKSYS wireless router, mod # WRT546 in my home for my PC. My internet connecting has gotten very slow and a friend advised other PC might be accessing my wireless and I should password protect my...
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Feb 09, 2010 | Linksys Wireless-G WRT54G Router
Will not connect to my network. PC sees my
have you manually entered the key code? did you add the device to your routers system?
Feb 04, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
I cant log on to the internet on my other computer it tells me minimal or no connection
Please ensure that your security settings are correct. Also make sure you have entered the correct password in your security enabled network (sounds like you are using a wireless connection). If you are behind a firewall or proxy server ensure that the internet settings are correct. If your are using IE go to tools - internet options- connections- LAN settings to setup your proxy if you are using Firefox go to tools - options - advanced - networks - settings tab to configure your proxy. The steps are almost identical for all browsers.
Sep 30, 2009 | Microsoft Computers & Internet
Apple iBook Mac Notebook Logo
119 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
