Question about Acer Altos G330 Server - G330-00084
Bios chasis intrusion setting - Acer Altos G330 Server - G330-00084
  • Acer Master
  • 3,606 Answers
Hello this problem occur when the case is opened.
A litle contact activate a setting in the bios, so unautorized personel can`t mess with the bios settings.
The wire can be removed from the mainboard, and the setting in the bios can be set off.
The user manual can be downloaded here:
http://support.acer.com/product/default.aspx?modelId=494
Adobe reader, is needed to read the content.
Good luck
Posted on Jan 29, 2013
Cmos checksum bad Chassis Intruded Fatal Error System Halted!
To remove CMOS Checksum error, you have to remove the coin cell battery from the motherboard and install a fresh one. A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For Chasis Intrusion msg, go to the BIOS (when prompted, press the Function Key at the system startup) and locate the option of chasis intrusion option and disable it, save settings. Commonly, to enter the BIOS you have to press F2, F10 or DEL Key, depending up the make/ model of the PC you have.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 08, 2011 | Computers & Internet
The problem of my computer is when i open my computer its not boot to windows it shows chassis intruded fatal error-system halted! what can i do to solve that problem? my board is asus p5sd2-vm.
chasis intrusion is an option in the bios, when U start the pc, press dell to go into the bios, walk trhough the settings ( I think it will be in a section advanced or security) where U can switch off intrusion.
Did U open the case recently?
Jun 16, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Chasis intruded ,after changing cmos battery also the sameproblem
Either jumper the chassis intrusion header on the motherboard with a striaght jumper(like you'd find on a hard drive), or, easier, somewhere in the bios setup you can set Chassis Intrusion detection or reporting to disable.
Sep 08, 2010 | ASUS P5GC-MX/1333 - Motherboard - micro...
When i open computer this massge fatal error chasis intruded
Your PC has a chasis intrusion detection chip installed.
This is common with most business class PC's.
Simply replacing the cover or defeating the chasis intrusion switch will remove the problem. Most people tape the button down if they leave their cases open.
Aug 30, 2010 | Computers & Internet
I am getting the fatal error chasis intruded error on every boot...motherboard model is p5sd2vm...rahul
Chassis intrusion can be disabled one of two ways.
First, Check your bios settings. There should be a security or PC health section where you can clear that error and disable the intrusion warning.
Second, there is likely a small switch near the chassis side when the side panel is removed. This is the chassis intrusion switch. It will likely lead to a 2 or 3-pin connection on the motherboard. this can be disconected without any ill effects.
Aug 13, 2010 | Computers & Internet
A massage display when started pc - chasis intruded, fatal error
enter the BIOS and turn of the chasis intrusion warning.
Jun 06, 2010 | ASUS P5GC-MX/1333 Motherboard
Chassis Intruded
try take out the battery on board for one min. then put in battery see if that works jim
Feb 16, 2010 | ASUS K8N Motherboard
Error Boot "Chasis Intruded fatal Error System Halted"
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
Nov 26, 2008 | ASUS P5P800S Motherboard
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
Request for Help
Hi, Muhammad, It sounds to like you have been infected with a virus and will need to run an antivirus program at bootup. If you are unable to do this yourself then it is not a big job for a computer technician to do for you. Regards mistyman
Aug 14, 2007 | IBM IntelliStation M Pro 6868 PC Desktop
Acer Altos G330 Server - G330-00084 Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
