Question about LG E500 Express Dual Series Notebook PC
I have a lg e500; my computer starts but hard disk does not spin and i have a black screen
My compaq e500 doesn't start. how can i reformat my compaq?
you cant format a computer if it does not start !
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
Sep 21, 2012 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
Windows xp black screen after lg logo solutions
Press the three key Ctrl+Alt+delete from your keypad when you see that black screen with cursor blinking,the scree will come up automatically or else try to switch the notebook in safe mode by following these instruction:
1. Turn on the notebook and keep pressing the F8 key from your keypad
2. You will find options like --Safe mode
--Safe mode with Networking
--Start window Normally
3. You need to select the Safe mode with networking option and then press enter from your keypad
This way you can get into the safe mode and you can easily use the notebook.
If the information helped you then please give me some ratings.Thanks
Jun 02, 2012 | LG E500 Express Dual Series Notebook PC
I just installed a new hard drive to the Aspire E500. When i boot with xp os it i says there is not hard drive found. it goes to a blue error screen, what is my problem?
check the juumper setting on the hard disk, the picture is given on the hard disk. set it on the primary, then again connect the hard disk and start your computer again
Sep 14, 2010 | Acer Aspire E500 PC Desktop
LG e500 won't boot up, black screen!!
I think this is a bios problem. Locate the bios lithium cell and replace it and try again
Oct 22, 2009 | LG E500 Express Dual Series Notebook PC
When i turn it on it says missing operating system??
1) you may check your laptop back cover there is a microsoft windows lable with CDkey, if so you may find any OEM windows disk to do installation.
2) can not find the lable, you need find a computer company to do a OEM installation more cheaper.
Feb 08, 2009 | LG E500 Express Dual Series Notebook PC
Non system disk or disk error
get a new hard drive and reinstall software + OS
May 06, 2008 | Compaq Armada E500 Notebook
Install xp-sp2 on compaq e500
First tell that which O/S it had earlier coz armada e500 notebook comes with 64 MB RAM and 12 GB HARD DISK , had you upgraded your notebook with RAM AND HARD DISK .
If not then check the hard disk space you have left in the notebook.
Apr 25, 2008 | Compaq Armada E500 Notebook
LG E500 Express Dual Series Notebook PC Logo
148 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
