Question about Gateway 2520915 Keyboard
My shift key hold on and put capital letter also it put sticky key on alot i cant do anything plz help
  • Anonymous Mar 09, 2009
    tHE KEY ON THE LEFT OF MY KEYBOARD WHICH DOES THE CAPITALS SEEMS TO HAVE STUCK AND I CAN'T SEEM TO UNDO IT.AT THE MOMENT THE KEY ITSELF IS OFF THE KEYBOARD AS I MADE A MESS OF IT GETTING IT OFF.HAVE TRIED TO PUT PASSWORDS IN AND THEY WILL NOT BE ACCEPTED BECAUSE THEY ARE IN CAPITALS.AS YOU CAN SEE FROM THIS EMAIL TO YOURSELVES THAT I AM IN CAPITAL ONLY MODE.HOPE YOU CAN ADVISE A SOLUTION FOR ME.
    THANK YOU.
    COLIN GOLDINGAY.
    Sergeant:
  • 367 Answers
By the sounds of it. Try gently prying the shift key off the keyboard. Pay attention to the spring. Clean with rubbing alcohol on que tip and you should be good to go.
Posted on Jan 27, 2009
I do not how to put in the capital in when I am doing the password on the tv
Hold down the shift key at the same time as the letter you wish to be capital.
Feb 05, 2015 | Televison & Video
Tip
Blackberry Tips
<br /> <img src="gfxcasa_0.jpg" /> <br /> <ul> <li>To move the cursor in a different direction, hold down the<i> Alt key</i> and roll the trackwheel.</li> <li>For a letter, hold the letter key until the capitalized letter appears.</li> <li>To go to a screen, press the Space key. To move a screen, press <i>Shift + Space key</i>.</li> <li>To move to the next item, press N. To go to the previous item, <i>press P</i>.</li> <li>In the<i> calendar</i>, to change the calendar view, press A. To switch to day mode, <i>press D</i>. To change to Week view, press W. To change to Month view, <i>press M</i>.</li> <li>Making use of the letter, hold the letter key until the capitalized letter appears.</li></ul>
on Dec 06, 2010 | Cell Phones
Left shift key types symbols not capital letters
it could be set to do so in system settings, like a shortcut. or there could internally be something inside under the keys which causes it to do that
Nov 03, 2013 | Computers & Internet
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Rgds,
Divya
Sep 02, 2012 | HP (395366-001) Keyboard
I am trying to do a cap and can't figure out how to to change frame setting to be able to do this
Are you talking about making text capitalized?
If so, then all you need to do is hold down your "shift" key on the bottom left of your keyboard at the same time you press the letter in which you want to make capital and then release both keys.
If you want to type a whole line of capitalized letters, press the "cap lock" key on the bottom left side of your keyboard and then you dont have to hold down the shift key.
Mar 06, 2011 | Computers & Internet
How to change the uppercase and lowercase letters
Either by pressing and holding the shift key (on left and right of keyboard, looks like up arrow) while typing, or by pressing the CAPS LOCK key to put capitals on or off. The caps lock key is usually one above the left shift key.
If you cant find them just advise your make and model of computer and I could tell you exactly where the keys are.
Oct 31, 2010 | Computers & Internet
How to type in capital letters on facit typewriter?
You did not specify if it was a manual or electric or the model, so assuming it is a standard manual or electric machine, push down on the shift key and hold it, then type your letter or letters. If you are typing everything in caps, press the shift lock key.
Aug 20, 2009 | Office Equipment & Supplies
When i hold my shift button down it doesn't capitalize the letter...and then when i let go of the shift button and then type the second letter that letter is capitalized. this is supposed to happen when...
I called up logitech support and they said it isn't the keyboard that was messed up it says that the sticky keys were on which is a Microsoft feature. What you have to do is go to Start, Control Panel, Accessibility Options. When you get in there you go to the box that says Sticky Keys and go into Settings. Uncheck the boxes in the option box that say: Press modifier key twice to lock, and, Turn StickyKeys off if two keys are pressed at once. That worked for me and I am also running Windows XP.
Jan 29, 2009 | Computers & Internet
How do you make you r letters capitol on sign in page for email
You can make the letters capital just by pressing "0" key
"0" key here works as a SHIFT key of computer
You will notice that when you press this key, there is a
change in upper right corner, for example look like this:
"abc" All small letter
"Abc" First capital and others small
"ABC" All small letter
Jan 14, 2008 | Cell Phones
Swintec 7040
Look for a slide showing 10,12,and 15 select 10. to bold hold down the code key and press the bold key. to capatlize hold down the shift key.
Jan 10, 2008 | Swintec 7040 Typewriter
Gateway 2520915 Keyboard Logo
171 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
