Question about Hotpoint WMA46 Front Load Washer
Hotpoint aquarius extra wma46
The washing machine has water in the drum which hasn't drained. i can't seen to find a filter or can see anywhere which is blocked, thanks Anthony
  • Anthony Quinn Jul 25, 2007
    we have had a look and have managed to drain the water what we think it was is the lock broke during a wash which ended the wash halfway through (thus leaving the water inside) the machine doesn't work now as its not locking. are these easily replaceable?
    Thanks
    Anthony
  • Anthony Quinn Oct 13, 2007
    hello again we fitted the new lock but the door locked light is still flahing and its still not running do you know any other options?
    Thanks
    Anthony
  • 5,911 Answers
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
Posted on Jul 22, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 25, 2007
    If the door latch is broken, the washer will definitely not start or complete a cycle. The latch itself is fairly easy to replace. It should be held in by a few screws and a connector plug. Getting to it is usually the challenge, though. You will need to remove the rubber door boot from the around the outer door opening to access behind the front case. You do not need to remove the boot completely. Just the outer portion that fits around the door opening. This should give you easy access to the latch and connector(s). Make sure you unplug the machine prior to servicing. I hope this answers your question.
Washing machine has died and I dont know how to drain water from drum. HOTPOINT AQUARIUS EXTRA WMS38
hello get a bowl or bucket and position the drain hose a low as possible the water should drain out .as for the machine dying do you mean it's total dead if so check the fuse in the plug if ok then check the fuse inside the washer's power supply it's a glass type hope it helps
regards
shaun
Mar 26, 2011 | Hotpoint Washing Machines
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Aug 28, 2009 | Washing Machines
Hotpoint WD51P First Edition 1100
two possible cause. 1)drain pump motor faulty. 2)some thing struk inside the pump. it easy to locate the pump ,normally at the bottom near the draining pipe .hope it help
Aug 02, 2007 | Hotpoint WMA46 Front Load Washer
Washing still wet - door won't open.
not a fault with washer. i guess you are plumbed into trap under sink. the spigot you fastened drain hose to is blanked off - there are various methods of doing this including have to saw off the end of the spigot with the bread knife. possible also a fault with pump or filter
Nov 16, 2006 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
635 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
