Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
500GB MY BOOK hard drive.how to clear "disk error" & use again?
I have a new 500GB MY BOOK hard drive. A "disc error" occurred while I was copying large files from another drive......now my computer won't boot up with 500GB drive attached.....how can i clear error and use drive again?
  • 46 Answers
When you reboot your computer, do not have the hard drive attached. As far as the error goes, im not to sure about that.
Posted on Jan 27, 2009
SOURCE:
Get error message at boot up Asus Eee 1005pe net book one year old. 'a disc read error occurred press ctrl-alt-delete to restart'
sounds like your boot ini file is corrupt if you have os disc put it in and try and repair.otherwise you may have to reformat hard drive
Jun 20, 2011 | ASUS Eee PC 900 Notebook
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
Sorry, the operation could not be completed because an unexpected error occurred. (error code 0)
The disk-drive has malfunctioned.
Search online for a professional "data recovery service".
For a significant fee, they can repair your disk-drive,
just long-enough to copy your files to a new disk-drive.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 23, 2010 | Western Digital 500GB My Book World...
I was copying something from my External Drive to my computer hard drive. the copy froze and my computer froze i had to restart and ever since I can't get my External Drive to connect to my computer.
you need to scan your external hard drive for bad sectors problems, you can use winpe mini cd, its a live cd that have hirens boot disk inside it as well as a preinstalled windows eviorment that will give you access to many tools and softwares...download it , burn it to disk and boot it.....
the idea is when you was copying files, some read errors occured that crashed the system, and whene the system crashed, bad sectors/clusters appears, and they need to be scaned and fixed.
May 11, 2010 | Western Digital My Book Essential Edition...
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
Dell Vostro 200 desktop with Windows XP is not able to handle two
Vista doesn't generally like to be installed on a hard drive that big. Well, Windows, in general doesn't.
And, from the sounds of it, you didn't install Windows on your new primary 1.5TB drive, you just copied it from the 500GB drive, which won't work.
Here's what you should to, to solve this:
1) Swap out your 1.5TB drive with the 500GB drive again.
2) Swap out your secondard 1.5TB drive, with the new one.
3) Create a partition of 120GB or less on that drive
4) Install Windows on the new partition.
5) Put the other 1.5TB drive back in, as secondary.
Once that's done, you can swap out the new 1.5TB drive with your Windows partition on it, in place of the 500GB drive.
When you boot, Windows may ask you to select which operating system you want, just select Windows Vista, and you should be good to go.
I had a similar issue a few years ago, when I tried to install Windows on a 1TB drive, and couldn't get it to work. Once I partitioned a smaller space, it worked like magic.
Mar 20, 2009 | Dell Vostro 200 Desktop Computer Intel...
Help!! Western digital 500gb external hard drive ticking noise
Yes. This is going to sound strange. Put the drive in a plastic bag and put it in the freezer. Next day, take it out, hook it up, and see if it is recognized.
If so, under My computer, right click on the drive - click Properties - then Tools, then Error Checking. Check box Automatically Fix File System Errors. Let it run. If everything shows up, be ready to transfer wnat you want off of it.
Freezing shrinks the metal parts . Microscopically, but often enough to get stuck parts free enough to get working.
I just went through this with a 750Gig Book. now i have reformatted the drive (after transferring all over to new drive) and the clicking is gone and all disk checks are fine and i wonder whether to trust this device ever again... Hate to just throw out a large drive.
Mar 10, 2009 | Western Digital My Book Essential 500GB...
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
Cant download large files to my book
The controller board in Mybook might not support files over 4 gb. Check with the manufacturer if there are any new drivers for you product to solve your dilema. You could also just buy a cheap external case for the drive in the mybook and swap it out. None of the new cases have these limitations and you can get them online for less than 20 bucks. I like MAD Dog cases myself. I hope this helps you.
George
Jul 15, 2008 | Western Digital 500GB My Book World...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
258 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
