Question about HP Designjet T770 24" Wide-Format Inkjet Printer
Designjet T770 blank screen and beeps 5 times
Main PCA just replaced as well as HDD
4 Suggested Answers
seeker5211
  • 1089 Answers
SOURCE: HP Designjet T770 HDD error
Did it ever work?
You are using the Post Script drivers, right?
Power down the printer from the back. Disconnect the power cord. Plug it back in and power it up.
Check the graphic language setting of the printer(look at the User Guide)
Resend the file.
Upgrade the firmware to the latest version (www.hp.com/#support)
Posted on Feb 10, 2011
Testimonial: "thanks, We actually had someone from another governmnet department that uses the exact same printer. and once we connected he gave the exact advice. "
  • 1116 Answers
SOURCE: Just got a new HP
Issue with the service station. Turn off and turn on your printer couple of times. Try moving the carriage assy., manually.
Still if it don't work then the service station would have gone bad. Needs to be replaced.
Posted on May 24, 2011
seeker5211
  • 1089 Answers
SOURCE: I'm getting 47:01 error on
It doesn't need cleaning, it needs to be replaced. It's located on the right side of the printer behind the ride side cover. If you haven't been trained you arn't going to replace the motor. After it gets replaced the printer has to be re-calibrated. If it is still under warranty, use it. Otherwise, get a designjet tech to work on it.
Posted on Aug 25, 2011
What does error code 02:1:10 mean?
Carriage PCA has failed and will require replacement. You could also check all the cabling to ensure connections are seated properly.
Aug 24, 2015 | HP DESIGNJET T770 Printer
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
PAPER JAM WITHOUT ANY PAPER FEEDED
there is a common fault on this particular printer which also affects the t770/t1200
when trying to feed a new roll of paper the plotter is asking to remove the paper from manual feed even though there is none.
the fault lies with the way the plotter is using the manual feed sensor,
there has been a technical release from HP regarding this same issue.
what to do -
1) firstly you need to find out whether the sensor really is at fault or if there is another fault which is confusing the manual sensor output.
a:- upgrade the firmware on the plotter ( always make sure your plotters firmware is upto date), cycle the power of the plotter and retry.
b:-use your user operating guide to take you through 'calibrating manual feed sensor' and retry.this is a quick process which sets the values for paper present/not present on the formatter.
c:- if the above two have failed then order a new PCA and calibrate the sensor immediately after first initialize of new Main PCA.
if the sensor fails to calibrate then I would first order a new sensor ( cheapest option first) if that fails then replace the main PCA. but always first check for any new firmwares.
Aug 19, 2013 | HP Designjet T610 InkJet Printer
How to find star wheel motor in hp designjet T770 hdd printer
Are you tech guy?..If not don't try to open it..its is not so easy..Remove left coverRemove main PCARemove Spit onThere you can see the star wheel unit..
Sep 14, 2011 | HP DESIGNJET T770 Printer
Hi ! can you tel me how to resolve eror code 47.1 for hp designjet t1100
I have this error with my Designjet T1110. I followed the instructions in the service manual 2-14 for troubleshooting.
questions:
- instructions say :"Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA." but I could not locate any cable from the starwheel assembly to the main PCA. I could see only cable from the starwheel motor assembly to the main PCA.
Feb 25, 2011 | HP Designjet T1100 Photo Printer
My Hp Designjet T1120 fails to initialize. When mains is switched ON the Front Display Panel in the plooter illuminate without any display and the Power switch in the display panel flickers with green...
Reset the formatter & check,,
Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. 11_19_2011_3_40_14_pm.jpg
Oct 11, 2010 | HP DESIGNJET T1120 44 Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
Dead hard drive in 1055CM DesignJet Plotter to replace
you can run this printer without an hdd. disconnect the power from the hdd.you may have to disconnect the IDE controller (the small board that connects to the main pca) and disconnect the flat grey cable. this makes your DJ1055CM a DJ1050C it should print okay. you cannot format any hdd to work. you must buy the hdd from HP. if you can find one. good luck and i hope this helped.
May 28, 2009 | HP DesignJet 1055cm InkJet Printer
Hard disc
Switch off the Printer and remove the Power Cord.
1. Remove 6 T-15 screws (Type B) from
the HDD Access Cover. Remove the
HDD Access Cover.
2. Remove the HDD with its foam holder.
3.
Disconnect the HDD Cable and Power
Supply Cable from the HDD.
When Installing the Hard Disk Drive make sure the holder is
placed in the right position so that it cannot move.
When the Hard Disk Drive is
replaced perform the
following Service Utility: Backup EEROM
Backup EEROM
This Service Utility is used to restore the contents of the EEROM
when a service engineer has replaced the Main PCA or the Hard
Disk Drive. If the Main PCA is replaced the EEROM content,
backed up on the hard disk, is restored to the Main PCA and if the
Hard Disk Drive is replaced the EEROM content is saved to the new
Hard Disk Drive.
Before using this utility, make sure that you are using Firmware
version A.02.xx. If NOT, make sure that you upgrade the
Firmware version to A.02.xx BEFORE using this utility.
1. In the Service Utilities submenu, scroll to "1.6 Backup EEROM"
and press Enter.
2. Select the part that has been replaced and press Enter
3. If you select "Hard Disk Drive (HDD)" a message confirming
selection is displayed. Press Enter to confirm and exit this utility or
press Back to cancel.
4. Press Back to return to the Service Utilities menu.
Sep 23, 2008 | HP Designjet 5500 (42 in.) InkJet Printer
HP Designjet T770 24" Wide-Format Inkjet Printer Logo
Seeker5211
Seeker5211
