Question about Dream Maker Spas Pool & Spa
What is wrong when control panel on eclipse dream maker spa shows error code 888 801
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 12650 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Easy spa round - dream maker - overheat sensor is
Assuming that you've got adequate water flow, clean/new filter and the pump works as it should; Try a new sensor. They can and do sometimes fail and the sensor is much cheaper than the PCB. ;)
Cheers,
Ian, from: http://hottub.synthasite.com
Posted on Jun 18, 2010
  • 990 Answers
SOURCE: Plugged in our EZ Spa for first time - panel shows 'SN'
Open your drain for a moment till you get water or force water into the skimmer. If you have an air lock in the pipes this will stop the spa from working.
Posted on Jun 26, 2010
EC keeps showing on my temperature screen can not find anything in the instructions. Help
Means "Economy"
You probably have a Balboa Control System.
Find the "Code" number on the label of the unit and do a Google Search. Find how to switch between Economy and Standard.
I recommend that spas be on Standard.
But if the spa is hot and is not giving you any problems, and the only irritant you have is not knowing what EC means, you can leave it alone, since you now Know.
Good Luck
Sep 26, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
Why does my Dream Maker Eclipse motor shut off a second after it goes on...plug new, power OK
either shorted heater element or pump motor bad unplug one at a time turn on see which one makes it blow
Jul 06, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a dream maker eclipse spa. I am getting an SN error message. I know this means there is somthing wrong with the sensors. I have replaced the sensors as well as the control module on top of the...
If you have replaced the hi limit sensor and the temperature sensor, and you are sure they are good, then the only thing left for this symptom is a bad circuit board.
May 17, 2014 | Dream Maker Spas Dream Maker Spa - Eclipse...
I have a vita duet spa. It has a pb error and the jets or the lights will not turn on. Any suggestions?
Vita Spa Error code (PB) is a power board communication error. Turn off the power and then check the connection between the topside control and control box. check for loose or unplugged wires, unplug the topside control (after turning off the power) and check for signs of shorts or charring on the wiring ribbon/connectors. If you cannot find the source of the problem you will need to contact your dealer or repair technician. I hope this helps =)
Nov 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a comfort spa portable hot tub with the pump housed within I am hearing a clicking noise and the dispaly shows the temperature readings ascending and the error code sn - what is the problem
This indicates a sensor failure. Either the temperature sensor has failed, or it has become disconnected from the control unit. If you find that it is still in place, replace the sensor.
Jul 11, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hello, I own a Dream Maker Eclipse 4-person Portable Spa. We have it on the porch, and we have noticed a leakage apparently between the pump and the filter. Do you have any suggestions how to fix the...
The Dream Maker Company (Dream Maker Spas, LLC) will be your best bet at finding a local service center in your area.
Email Customer Service @ lisav@dreammakerspas.com. You will normally receive a response in 24 hours. Be detailed about your location (City, State, Zip) and try to provide as much detail about your spa as possible.
Dec 08, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jun 25, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
What size shaft seal is in a dream maker eclipse spa? I need a new one to replace my leaking seal.
Your spa should have the aquaflo pump which uses a PS-200 seal.moz-screenshot-1.png
http://www.ussealmfg.com/pdfs/ChooseThe%20RightSeal.pdf
Oct 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
46 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
