Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Ge nautilus dishwasher
Dishwasher is not pulling water into the unit in the wash cycle, but does in the rinse cycle. I could probably fix myself, but dont know what I am looking at. Thanks for your time.
  • 51 Answers
Check inlet valves as if you have 2, it may fill using 2 inlets (hot & cold) but only rinse on using 1 ((cold only). So if the cold inlet is faulty, then you will only notice on the rinse. If thats not it then chances are it is the controller unit. regards
Posted on Jul 25, 2007
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap stays on botton of dishwasher
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, if you don't see any water at least once - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jul 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Water standing in the dishwasher at end
probably cant fix this your self. if your sink is draining ok then you probably have a problem with your circut board.
Apr 25, 2009 | GE Nautilus 24" Built-in Dishwasher
2 year old GE Nautilus dishwasher
Check the pump, make sure it is working properly and pumping water out. If it is then check the drain hose and make sure it is not plugged.
Feb 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus Dishwasher Problem
check water level is ok. check its heating. open door when in operation and check if spray arms are rotating. if not, take them out, run water into centre hole and check water comes out of jets. note the spray arms only rotate with water coming out of angled jets at end
Apr 19, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Help the water on my dishwasher is screwy.
The problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side on most models), in which case replace the water valve.
Nov 17, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
167 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
