Question about Refrigerators
Gi5svaxvl01 is freezing the ice maker fill line.
5 Suggested Answers
SOURCE: Ice maker freezes up
Icemaker Fill Tube Freezing Make sure the water supply is greater than 20 psi. If too low, the water valve won't seat properly and it'll "weep." Common causes of low pressure are gunked-up saddle tap valves, kinked water supply line, and using a reverse osmosis filter to supply water to the icemaker. Check to see if the black, flexible portion of the fill tube is wrinkled, twisted, or kinked which can cause ice dams that block the fill tube. It turns out that the manufacturer's have been scratching their heads about this, too, and have concluded that the new fill tube air slit design helps prevent this problem.
Posted on Sep 25, 2006
  • 11 Answers
SOURCE: Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Posted on Oct 16, 2006
  • 150 Answers
SOURCE: Ice Maker does not fill with water
water valve or the ice maker is malfunctioning and not calling for water
Posted on May 07, 2008
Sea Breeze
  • 4655 Answers
SOURCE: I have a Frigidaire Model#
The most likely reason for this happening is a defective Click Here=> 241734301 Triple Water Control Valve These valves are located on rear of refrigerator and near floor where the water supply enters your Refrigerator. CLICK HERE=> FRS26H5ASB9 USE AND CARE GUIDE
The valve location is listed on page 5 of the Use and Care Guide, If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) This problem is typical as a leaky faucet that drips even when the water valve is turned off. I will be here to answer any questions you may have, Thanks Sea Breeze
If helpful please rate this solution, Thank You
Posted on Jul 16, 2011
Water flow tube on ice maker leaking by causing ice blockage
When the ice maker calls for water, the valve sends water to the ice maker in the appropriate amount and then shuts off, sending no more water until the ice maker calls for it again. If the water fill line is freezing up, this will cause a leak the next time the ice maker calls for water. The water has to go somewhere. The problem is more than likely the the water valve. It is not shutting off completely and it is allowing a small trickle of water to be constantly sent to the ice maker. This causes the fill line to freeze up and clog. Replace the water valve and defrost the water fill line and solve the problem.
Apr 06, 2014 | GE Refrigerators
U line water comes in shuts off the fills again before freezeing cubes
the thermostat is what determines when the ice maker should start a harvest, could also be a bad valve
Mar 05, 2014 | Kitchen Appliances - Others
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
My freezer is not freezing anymore please help as can not afford a new one ..thank you
Follow the steps mentioned below to solve the problem:
First remove the ice bin and look inside the mold of the ice maker to see if it is full of ice. If the ice sensing arm is down ( on position) and the ice maker is full of ice, there is a failure inside the ice maker and the ice maker should be replaced.
If there is no ice in the ice maker, look at the fill tube on the rear of the ice maker. If the fill tube is frozen up the ice maker can't fill.
You can defrost the fill tube with a hair dryer.
The water valve on the rear of the refrigerator supplies water to the water dispenser and the ice maker. Since the water dispenser is working, the only line that could be blocked runs up the back of the cabinet and attaches to the fill tube for the ice maker. The water valve could be bad and not sending water to the ice maker.
If the fill tube freezes again you should replace the water valve.
Hope this helps.
Shane
Mar 16, 2011 | Whirlpool ET8WTKXK Top Freezer...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
Sep 16, 2009 | Refrigerators
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
