Question about Kenmore 24032\24036 Top Load Washer
Replacing the dog something or others in the agitater
How to remove the agitater,to get to the part to be replaced
  • 640 Answers
Remove cap or dispencer,,pull straght up..now look down inside agitator and pull the plastic cover up with your hand,,now we need a wrecket to remove that have in bolt..remember the agitator has 2 parts,,now the top piece is called the auger,,and the bottom piece with the paddles is the agitator..pull up from the auger mostly you pull the agitator off to..now the part you need is inside the auger ,,just turn auger upside down remove whith plastic cam,,replace dogs on cam,,and reverse process to put togher
Posted on Jan 27, 2009
  • 5,911 Answers
The following link explains what "agitator dogs" are, and gives the steps necessary to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Will not drain, spin or agitate
make this test and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dog .
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente motor coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Jul 25, 2013 | Washing Machines
Vbsr2080woww
follow this steps and fix it. God bless you
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dogs follow video.
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente of motor coupler
Transmission
Jul 09, 2013 | Washing Machines
Agitator not working wont wash water does drain
see this steps and fix it. GOd bless you
Agitator Dogs
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of motor coupler
Transmission
Will not agitate, motor runs ok and will spin dry ok.installed a slightly shorter drive belt on and it would agitate but not spin dry, I have a new bet kit ordered is there something else to check, th
see this causes and fix it. God bless you
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitaor dogs follow video.
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
Oct 02, 2012 | Maytag Washing Machines
After top load washer fills with water you can hear the agitator but the agitator does not move
IF WIRLPOOL AGITATOR DOGS FUNNY A REMOVE CAP OF AGETATER REMOVE CAP INSIDE AGITATER REMOVE 7-16 NUT PULL AGITATER OFF FIRST CHECK TO SEE IF IT SPINS IF IT DOES DOGS IF NOT A DRIVE COUPLER IS YOU PROP ITS INBETWEEN YOUR PUMP AND MOTOR
Apr 03, 2010 | Washing Machines
Series 70 washer model 110 26712690 agitator does not move, is this difficult to fix, how much is the cost
it is a .99 cent fix,pop the top off the agitater,remove the 7/16 bolt,pull the top half of agitater off,there are 4 small gears in there called dogs,they need to be replaced,you can get them from your local appliance parts store,put it all back together and your done-mike
Feb 10, 2010 | Kenmore Washing Machines
Top part of agitator won't rotate good
This is commonly caused by worn agitator dogs. The following link explains what they are, and how to replace them:
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is AP3094543 and sells for about $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance.
If you have any questions about this repair, please let me know. I hope this helps you.
Oct 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top of agitator does not agitate with lower agitator.(dual agitation) whirlpool model LA3860XW00
You will need to replace the Dogs. Take cap off of the center of the agitater, take bolt out of center and pull agitater up and off. Pull two pieces apart. There are four dogs that catch on gear teeth inside your agitater. The four dogs come in a hit, sometimes with a couple other pieces. Has to do with which model you have) replace these four and any other pieces that come in the kit you order. This will fix your problem.
Please rate solution
Aug 31, 2009 | Whirlpool Washing Machines
Kenmore 90 series washer 110.28902790
if you remove the agitater cap and the inside cap,you will see what they call dogs(4 of them)they wear out and the agitater will not wotk,if you remove the 7/16 bolt and pull the agitater off you can replace them and all will be fine,you can get them at your local appliance part store,please leave me a fixya-mike
Mar 12, 2009 | Kenmore 15864/15862 Top Load Washer
Estate top load washer
it you pop the top on the agitater you will see 4 gears called dogs, remove the 7/16 bolt upll the top half of agitater out and replace the dogs,you can get them at your local appliance part store,let me know how you do-mike
Oct 27, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore 24032\24036 Top Load Washer Logo
89 people viewed this question
Sal De
fordexpert
Robert Rankin
