Question about Refrigerators
Fcrs201lfb5 not cold
Compressor runs fans run just not cold
dididsaythat
  • 291 Answers
SOURCE: frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Posted on Sep 12, 2007
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
landsend
  • 1066 Answers
SOURCE: freezer cold, fridge warm
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My fridge is not cold though the compressor is running.
If any fans stop cooling stops. The fan inside the freezer will need to be examined for why it stopped or if the one below is stopped it to will need to be checked. I think your defrost timer is on the front of your refrigerator on floor behind the kick plate. If you can turn the timer clockwise until refrigerator starts or stops that may tell us the reason for these failures. Place your model in the model search feature below and choose one of many the same models. Look inside back of freezer wall after you unplug refrigerator and tell me if fan is stopped and if coils have ice or snow covering them.Then we will go from there.Click link below. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: It does not continuously run and it is not cold
These units are not repairable.(per Maytag) The entire unit must be replaced.(per Maytag)
Posted on May 26, 2009
No cold air
fan is likely gone. You can hook up a standard portable fan until you can get and install the replacement fan. Just MAKE SURE you've cut off the power (presumably this is a fridge) while you're wiring in the new part - then and only then- turn on the power. If that fails, check your connections. Still fails, you have a different problem.
Jul 15, 2017 | Heating & Cooling
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Compressor runs but fans dont.
If the compressor is running and pumping with no heat produced, you have lost refrigerant.. Most modern freezers have a controlled fan so the coil can freeze before the fan starts.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
Compressor runs but wont cool
Make sure the compressor is running it should be vibrating and get warm after a few minutes. If it is indeed running the smaller tube to the compressor should be getting warm if not it could very well be the compressor has stopped pumping. If the fans are not running they could be controlled from the control board and will come on when the sensors on the evaporator get to a certain temperature. I does sound like the compressor is the problem.
NOT GETTING COLD
the first thing to check is the thermostat if its stoped working them it wont be telling the compressor to start up and the unit wont get cold,,
have this looked at first as its the cheapest part to renew
May 22, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
The lights are on in the refrigerator and freezer, but neither unit is cold. The thermometer on the refrigerator registers 55 degrees. Why is it not cooling??
First, make sure the compressor is running. It is underneath the refrigerator body. If the compressor is running, and you still don't have cold air, check the compressor fan. This should be close to the compressor. This fan draws air across the coils and removes heat from them. The compressor and fan must both be operating properly to get cold air.
Oct 18, 2009 | Refrigerators
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
