Question about HP ProLiant DL380 G5 (458561001) Server
IP not pinging after firmware upgrade on DL380G5 server
  • HP Master
  • 2,878 Answers
Check lights on NIC, cables, ports, and IP configuration (DHCP). These are all things to check.
Posted on Jan 23, 2013
Lost wireless internet to our MAC OSX 10.5 Resetting ISP didn't help. Running Network diagnostics didn't help. Our ISP, Telus says it isn't their problem. Wireless is working on our non-MAC computer. It...
Did this occur after an OS update was installed? There's some history of dropped connections due to Mac updates...Check the Dlink site for firmware upgrades for your router, and install them, and see if that fixes it...
Aug 18, 2009 | Computers & Internet
Looking 4 a TFTP server for upgrades
There must be a tftp server on your network, that must have files on the server that are needed top upgrade the firmware. Ask your admin, as they will have the IP address. I can refer you to a tftp program you can install on a server, if need be.
May 27, 2009 | Hitachi IP-3000 IP Wireless Phone
I need to be able to ping the SonicWall TZ190 wan ip from the Internet for tracert puposes. There is no ping response to that IP address. The manual says. Click Objects, and then Services. Verify that...
Saibrains is correct unless your firmware is of earlier version. you might have to upgrade your firmware. Also you can not use a port #
No ports required for Ping as it uses icmp packets
It needs to allow icmp 'echo-request' (type 8) packets out and icmp 'echo-reply' (type 0) packets in
to allow ping request. On earlier versions of the sonicwall firmware it only absorbed Ping request as to stop hackers from ping attacking pass the firewall.
check the manufactures website for your model and see if they have newwer firmware.
The GUI should have a place where you can set it up
Apr 09, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
USR 5461 can't be configured
Verify 1st if you can still communicate with the router, if your running WIndows go to the command prompt and type ipconfig, check your default gateway address(192.168.x.x) then type ping(space)192.168.x.x if your getting replies your still lucky that means the firmware was just incomplete and to complete this without accessing the configuration utility, you need a tftp server installed on yuor computer to load the firmware of the router, check if your router manufacturer has a recommended tftp server, if not download any tftp server software from 3rd party manufacturer such as linksys or netgear, dlink. When you open the tftp software it will normally prompt you to enter the following information - ip address of the device you want to upgrade, password and the ocation of the file you need to load on the device(in this case the firmware(.bin) that you downloaded).
Hope this will help you get your router uo and running,
Regards.
Aug 26, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Power indicator keep on blinking
hello!
blinking power light after firmware upgrade sometimes indicates that the upgrade is not sucessful or the firmware that you load is incorrect.
-- try to reset the router for 30secs and check if the power light is still blinking
-- if its still blinking check your pc's ip address while connected to the router
-- if the ip address of your pc is invalid (169.x.x.x.) turn to manually assign static ip address to your computer and check if you can ping your routers ip address
-- if you can ping the routers ip address, upload the correct firmware to your router
-- if you cant ping your routers ip address still, reset the router again and try to ping the routers ip address once again
-- try to change port and cables
-- if still unable to ping the routers ip address, chances are that the router might be defective now
Apr 29, 2008 | Linksys Wireless-G WRT54GS Router...
Firmware problems
Check if you can still connect to the the camera's UI, connect it to a router or computer. Try to ping its IP address and access the camera's UI, if ur able to access it, try to do the firmware upgrade again.
Mar 07, 2008 | Linksys Wireless-G WVC54G Network Camera
Linksys print server Model EPSX3
Firmware upgrade for your print server could fix your problem or kill your print server.
Try this first: SET UP A STANDARD TCP/IP port.
Set a static ip on the print server. Use that ip address to set up your STANDARD TCP/IP PORT. You can do this on the printers and faxes page.
Right click the default printer then click properties. You have to ADD A NEW PORT.
Good Day
Nov 05, 2007 | Linksys EtherFast 10/100 (epsx3/uk) Print...
How to install pocket printer server
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Aug 07, 2007 | Emulex NetQue Pro2 (NP02) Print Server
Emulex NetQue Pro2 Print Server how do I connect to it
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
HP ProLiant DL380 G5 (458561001) Server Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
