Question about SanDisk Sansa m240 MP3 Player
Sound My Sansa turns on and it appears like the song is playing. The sound bar is white and when I try to increase the volume turns white again. I did try installing a new battery & that didn't work
When I have this problem, I go to the menu, highlight fm radio and the sound comes bac. Then I go back to 'play music mode' . It's worked every tme.
Posted on Aug 14, 2007
SOURCE:
Sound Problem
Sounds like something's up with your EQ. From the main menu, go to Music>Music Options>Music EQ and try another setting or play around with Custom. Could also be volume. Go to main menu>Settings>Reset All (NOT FORMAT!!!) Recommend trying both in given order. Hope this helps.
Jan 06, 2010 | SanDisk Sansa Clip MP3 Player
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Songs won't play on mp3 after they are loaded
Do you see the numbers advancing? Have you checked your software sound settings plus computer volume settings? What Sansa model do you have?
Aug 12, 2009 | Audio Players & Recorders
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
My sandisk sansa clip mp3 player does not play songs/no sound.
I later found out that while trying to download more songs, the entire songs in my sandisk mp3 was corrupted by a virus. I solved the problem by formatting the device and thereafter downloaded new songs into it. As soon as I did that, the songs started playing normally at full volume.
Mar 06, 2009 | SanDisk Sansa Clip MP3 Player
White screen only on E260 4 GB-cannot get to the menu or anything
Adjust the volume while playing by "turning" the thumbwheel. Go clockwise to increase, counterclockwise to decrease.
Jan 05, 2009 | SanDisk Sansa e260 MP3 Player
MF326 play
Try increasing the volume. If it still does not work, then your jack is dead.There is not a repair service for these, so you will have to replace the player.
Jun 27, 2008 | Matsunichi MF326 MP3 Player
Can't increase volume
Hold the Menu button until u see: Search.
Then go down to AVLS: then it will say "on" next to it. hit vol. up, then the down button, play/stop.
Finally hit "Menu" again to go back to music
Nov 02, 2007 | Sony Walkman Bean NW-E305 MP3 Player
Sansa MP3 M240 No volume when playing songs, says to synch
Where did you download the songs? Napster?Rhapsody? Any online music stores? Try synchronizing them using their software. If you have ripped songs from a cd you may want to rip them again and before ripping them check this option on your windows media player software. Tools > Options then under RIP MUSIC remove the check mark that say's Copy Protect Music or choose the file format as MP3. Then format the device using the windows media player software(for version 10 = click on the sync tab then choose the pencil like icon on the far right, for version 11 = right click on the sync tab choose the player and choose format) use after doing that rerip the songs using the windows media player software.
Jul 14, 2007 | SanDisk Sansa m240 MP3 Player
Ringing sound when playing music
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 22, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
87 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
