Question about Clarion DXZ545MP CD Player
Sub woofer volume adjustment
Currently the subwoofer level can only be set from the gain dial on the amplifier.  When I turn the volume on my radio to zero the sub still produces at the level set.  I would like it to decrese and raise with the volume is that possible, or even to control it from a setting on the stereo?  What speaker wire size is standard for amp to sub connection.  Thanks.
  • beantownsfin Jan 29, 2009
    can I connect the subwoofer and stereo unit so they work together?
  • Anonymous May 23, 2009
    low volume & not dolby
    Problem Solver:
  • 9 Answers
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Posted on Jan 28, 2009
  • grodenbarg
    grodenbarg Jan 29, 2009
    no, you need the amplifier. The best way without specialized tools is to adjust the amp is by ear. Set the gain to the lowest setting first. Listen to music, or bass test cd at you usual volume (high, but not full blast) at the stereo, then adjust the gain until the sound is loud. When you start hearing distortion at your subs, then immediately turn down the gain to the point where the music is clear, but still loud.
I have a clarion m 309 radio and I'm trying to hook up a fusion FM 402 amp for a sub woofer. I had all speakers playing but, I could not control the volume of the sub with the radio. I need to know...
Amps usually receive their signal through RCA wires. Your radio should have one pair of RCA outputs on the back. (red and white) You will adjust your subwoofer volume by adjusting the gains on the amplifer (little knob next to the RCA inputs of the amp), then you can turn up the bass on your radio.
Sep 06, 2011 | Clarion Car Audio & Video
I have a pair of kicker cvr 124 with a kole 1500 watt amp that is bridged to the woofers. the amp is 385 rms at 2 ohms where should the gain be to get the most power without distortion.
When setting your gain you want to set the gain high usually between 75% to 95%. if the gain is low than turning up the volume on your radio will only amplify the distortion coming from the under powered head unit. By turning up the gain you are maximizing the signal that is amplified coming from your head unit
Mar 20, 2011 | Kicker Car Audio & Video
Only powers subwoofers when at high volume
Well, make sure that the output level on your head unit is up, and also try adjusting the gain NEVER EVER PUT IT ON FULL GAIN BECAUSE THAT WILL CLIP THE AMP AND MAY BLOW AMP AND/OR SUB!!!
Oct 08, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Insignia NS-C5112 manuel. new sub getting too much sound through rca wires when turned up. sub amp shuts down. need to tune down audio in rca cables
does your new sub have a volume or gain control? If your getting the signal source from the line outs, then the volume level there is constant. You need to set it up so that it can be controlled by the main volume control.Or you might need a control pre-amplifier before your sub
Aug 18, 2009 | Car Audio & Video
PXA-H700 optimum set up...
The way the EQ is hooked up is correct.
You set the factory radio to a set level, then use the volume on the EQ for everyday adjustments.
I believe your problem lies in the amplification.
Your BOSE amplifier was made to run a 4 channel 8ohm stero load.
Low powered - high in sound quality.
You have swapped the factory 8 ohm speakers (15W) for 4 ohm power hungry ones.
Now the amplifier is working harder to produce the same output.
You would be best served eliminating the factory amplifier and getting 1 good 4 or 5 channel amp to power your speakers.
a 4 channel amplifier could be used stereo (left and right) on channels 1 and 2, (2ohm stereo load)
and bridge channels 3 and 4 for your subwoofer.
For a true surround sound - a 5 channel amplifier could run each speaker individually, and the 5th channel is reserved for the subwoofer.
a small dedicated 75wx4 channel amplifier with built in crossover, and level gain controls - would blow your socks off. It is 200x better than the factory 12Watt amplifier. Your ears will love you for it :D
If you need more help - just let me know.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 23, 2009 | Alpine PXA-H700 Car Video Player
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Sub woofer
Is there a gain control on the sub? If not, are you using a receiver or pre/processor to control volume? There could be a level adjust or on/off control for the subwoofer output.
Jan 20, 2008 | Pioneer VSX-D511 Receiver
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Cheers
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
Wiring Advice
they are to adjust output levels. yes you can hook up the sub to the amp. it is not wise to hook up the front speakers with the sub though. just get a less powered amp to drive the front speakers.
Oct 28, 2007 | Infinity 475A Car Audio Amplifier
Clarion DXZ545MP CD Player Logo
472 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
