Question about Minolta Office Equipment & Supplies
PF-118/PF-119 Minolta Copier Wireless Download
Added a new pc and can not detect the Minolta Copier through the wireless channel. Do not have disk or information on Wireless Copying
  • Minolta Master
  • 6,696 Answers
DO the other computers on the network ok with the copier. Sir the copier you have is Di200/251/351. if so the best driver you mite find is for windows 95 or XP at best for that machine will not work with anything new. It is a legacy machine from Minolta now Konica Minolta. PF-118/119 are the paper draws for that machine not the copier! try below but doubt it. Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 07, 2015
4 Suggested Answers
SOURCE: drivers for PCL5c printer/copier for mac
Basically all priners use the same protocols. Mostly we have PPD and NOW PCL5.
Right now I´m using a workcentre c226 however all the drivers I found on the Xerox homepage were PPD... they didn´t work. This is what I did:
I whent to Sistem Preferences->Print&Fax->(select your printer in the left side)->Options&Supplies->Driver->Select Driver to use...
Now using spotlight or reading all the drivers search for a printer that uses PCL5 and thats it. It doesn´t mater if its not the model you have.
For example with the WorkCentre c226 I use the driver of a HP LaserJet 3P w/ PCL5.
Posted on Jul 22, 2008
checkitright
  • 1362 Answers
SOURCE: Canon copier PC 420 making grinding noise during copying cycles
only two possibilities
1- fuser
2-gear stripped most likely with the scanning part
Posted on Oct 15, 2008
Cogz
  • 1326 Answers
SOURCE: copier malfunction
Have you just added a new toner? If so try this first.... Turn the power off and carefully remove the toner bottle you just put in.. Close the front door and turn the power back on and let the copier warm up to ready. Make one or two copies and open the front door and reinstall the toner bottle again... That should take care of the problem.... If it dose not work you probly have more of a major problem with the hopper unit..
Posted on Jun 19, 2009
Trying to activate my wireless connection for my acer acer aspire x1300 do I need a disk or can I press certain buttons to activate the wireless
The aspire Acer Aspire x1300 does not come standard with wireless. If you have added wireless capabilities, your hardware should have come with a disk containing drivers for your wireless device. If it didn't I would look up the manufacture's site and find the support or drivers download page.
Apr 16, 2014 | Acer Aspire X1200 Desktop PC - Athlon X2...
Tip
Wireless Security
Enable some array of wireless aegis like <b>WPA2</b>, if you accept no <b>wireless encryption</b> set up again all of your wireless audience can be tracked and accountable to exploit. Kismet and added hacker accoutrement will not alone detect wireless cartage they will additionally analyze all the wireless audience for that <a href="http://en.wikipedia.org/wiki/Avaya_Secure_Network_Access">wireless admission</a> points.
on Dec 28, 2010 | Computers & Internet
Internet keeps cutting off on my new laptop
If you are using a wireless connection then -
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Mar 17, 2012 | Computers & Internet
Our laptop and our Xbox 360 will not pick up the signal it did but something has happened and now neither will work
Always check the obvious first such as power to the router, all cable connections.
If connections are good then has anyone made any changes to the router recently.
If not then have you added a new cordelss phone or other wireless device to your home.
If not a neighbor may have added a wireless device that is interfering with your router. To check this Google "inssider" and download the free app and install it. Run the app and select the 2.4Ghz option to view all wireless devices within your range. You will see your routers SSID along with all other devices within range. If you see any other devices on the same channel as your device you will need to change the channel of your router. Channels 1,6 and 11 are isolated channels so if you are on channel 6 you would want to change your channel to either 1 or 11. If changing channels doesn't solve the problem and you have rebooted your router the unit may be bad.
Feb 26, 2011 | Linksys Wireless-G WRT54G Router
Belkin N150 routerlooses connection when microwave oven is turned on.
HI ..,
The router would drop the wireless signals if you have any cordless phone,microwave.. .. so keep the router a little far away from the kitchen and wireless devices .. or else you can try changing the wireless channel to no 11 or 9 or 6 are the best wireless channel below is the steps
Wireless routers can broadcast on several different channels, similar to the way radio stations use different channels. In the United States and Canada, the three main channels are 1, 6, and 11. There are more channels on the router, but they "overlap." Similar to how you'll hear interference on one radio station while another is perfectly clear, sometimes one wireless channel is clearer than others. You don't need to change your computer's configuration, because it automatically detects the router's new channel.
In order for a wireless device to connect to a wireless network, it must know the network name, or SSID (service set identifier). If you plug your wireless router or access point in and leave the default SSID, it won't take long for an attacker to determine what the SSID is.
To change your channel and SSID:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on "Channel and SSID" in the left-hand column under the Wireless heading.
  6. The router may be set to auto for the channel selection. This means that the first time the router is powered on, it will automatically select the channel that has the least amount of interference. As surrounding networks are added, the initial channel may become crowded. Use the drop-down list and select a new channel for your router.
    Note: Channels 1, 6, or 11 are the best selections.
  7. After setting the channel, select the SSID box by clicking in it.
  8. Type a name that is familiar to you. This is the name of the wireless signal on which your router will broadcast.
  9. Once these changes have been made, click the "Apply Changes" button toward the bottom of the screen.
Sep 26, 2010 | Belkin Computers & Internet
I can't see the the wifi network
Wireless routers can broadcast on several different channels, similar to the way radio stations use different channels. In the United States and Canada, these channels are 1, 6, and 11. Just like you'll sometimes hear interference on one radio station while another is perfectly clear, sometimes one wireless channel is clearer than others. Try changing your wireless router's channel through your router's configuration page to see if your signal strength improves. You don't need to change your computer's configuration, because it'll automatically detect the new channel.
Dec 28, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
My PC cannot see the wireless signal.
The reason why your PC can't see the wireless signal is because it is too far from the router. Or your wireless card is too weak to detect the signal from the router, its either the antenna it bad or loose, you may need to double check that. You may consider changing the channel on the wireless router to channel 11. Try to power cycle the router as well.
Jun 20, 2009 | SMC Barricade g SMC2804WBR Wireless Router
New final meter says it is not tx wattage
The ERF 2030 will not work with out the added companion parts that need to be added with!! I am assuming you had all the parts with the ERF 2030 and instructions??
The added parts are as follows: along with the ERF 2030
1-EN 1230 & 1- pF Ceramic disk capacitor
E-mail us for other details
Dennis
Nov 14, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Lg r 405 will not recognize wireless signal from lynksys wrt350n
hi i would suggest to access your routers setuppage and set the channel to channel 11.
make sure also if your wireless network is secured, type the correct key those things are case sensitive.
to access the routers setuppage go to a computers that is connected to your linksys router (wired) then launch IE on the address bar type 192.168.1.1(this is the routers ip) then it will ask you for username and password for the username dont type any thing for the password type admin.
when your on the setuppage click on wireless tab. while on the wireless page set the channel to 11.
after that click apply or save settings on the page.
then after that try to connect to your wireless network on your laptop.
for further help you can call linksys hot line 1800-3267114
they will surely help you with this.
hope this helps.
Oct 19, 2008 | LG X-Note LM50 Notebook
41 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
