Question about Istikbal Furniture
How do you open and close an istibal sofabed?
Ford escape 2014 power moon roof barely tilts open
This is normal. The reason it raises higher is due to the design of the sliding arms in the moon roof. without going into too much detail, the reason it raises before closing is to "unlock" itself from from the "Locked" open Position in order to get to the "Locked" closed position. Its a fancy way of making it seal well when closed and not rattle when open
Apr 10, 2014 | 2014 Ford Escape
Tip
Eaton Home Heartbeat Open/Closed Sensor Description
The Open/Closed Sensor can be attached to a window, door, cabinet,or anything else that you want to monitor the open/closed status. Itworks using a magnet and switch. When they are close together thesensor recognizes that the door or window is closed. Likewise, if thetwo pieces are far apart, it recognizes the door or window is open.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
on Jan 03, 2009 | Eaton Home Heartbeat Open/Closed Sensor
1999 Nissan Pathfinder sunroof tilt will not close. sunroof tilt open works but will not close. Motor to open works but motor will not energize to close. Jumpered power to close circuit and motor doe
-Sounds like the motor is effect on Reverse position.
-If jump power to either terminal. If it work on both, that mean the switch is bad. But If it works only one terminal that mean the motor.
Good Luck
Mai
Apr 04, 2014 | Vehicle Parts & Accessories
The trunk open indicator shows trunk open, but it's closed.
There is a switch in the trunk, that will close when the trunk is closed. This switch probably has become loose and out of adjustment, failing to work when trunk is closed. Find and readjust the trunk open\closed sensor.
Dec 04, 2013 | 2010 Volkswagen CC
Chelsea Faux Leather Futon Sofabed
I recommend that you maybe add more details to your question, so it will be easier for Experts to understand the question and answer it.
Sep 28, 2012 | Generic Chelsea Faux Leather Futon...
Where can I find a sofa bed that also has a chaise?
there are many types of sofa beds as the one you are looking for but I recommend that you'll get one that the chaise can be used as well, maybe as a storage box, like the one offered here: http://www.fantasticfurniture.com.au/ViewProduct/p/living/sofas/madrid-sofabed-storage-chaise
May 29, 2012 | Furniture
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
03 Jeep Liberty Sport sunroof wont close.
03 Jeep Liberty sunroof wont close. I have 4 sunroof buttons; Open, Close, Vent and ASC. Open and Vent buttons are working fine. Close button is not responding. ASC button is flashing red and green but does nothing when pushed. I have no way to get it closed
May 08, 2010 | 2003 Jeep Liberty
Cd drive opening and closing on its own
You never should have pried it open. Only use the manual eject pin-hole with a paperclip. Noe it seems the drive tray is damaged and will not close properly so it is constantly opening and closing trying to find home. The drive will need replaced.
Jan 02, 2009 | Dell INSPIRON 6000 CENTRINO...
Furniture Logo
Top Istikbal Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you an Istikbal Furniture Expert? Answer questions, earn points and help others
