Question about Alesis MICRON Analog Modeling Synthesizer
Micron problem! I just purchased a used alesis micron. Unfortunately, when I plugged in my headphones and also when I plugged it into the amp, there was a low buzzing sound, but no sound came from pressing the keys. What should I do with it? I reset it to the factory programming, but it didn't help.
  • edemast89
    edemast89 Jan 24, 2013
    I used a standard quarter inch cable and plugged it into my usual amp that I use for my nord normally. The same buzzing sound came from using my headphones as well. I'm not sure what else there is to say. I did try resetting it.
    Problem Solver:
  • 17 Answers
When you plug in the headphones it cuts the sound to the speakers. Unplug headphones (they are probably broken if you can't hear them). Make sure you are using stereo plugs.
Posted on Oct 16, 2013
5 Suggested Answers
  • 5603 Answers
SOURCE: Why won't my Alesis Micron clock sync to my Alesis SR18
Make sure the SR16 is set to send the clock out. Read 6.6 of your user's manual.
Posted on Aug 25, 2009
  • 5603 Answers
SOURCE: have the alesis dm6
Two things:
Check that cables are seated, especially the one at the main module.
Second, look for a setting for "Local Control" in your user's manual; That setting should be "On" to accept the triggers from the pads.
Posted on Jan 12, 2011
  • 5603 Answers
SOURCE: Alesis DM6 electronic drum kit module sound
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
Posted on May 08, 2011
  • 5603 Answers
SOURCE: Hi team! I've just bought an Alesis Q49
That is what you can use transpose for... Now the truth is revealed: What transpose does is JUST move the notes (including the black keys) up and down the keyboard... that is ALL transpose does... so if you transpose +1 when you hit C the keyboard emits C# and hitting C# emits D and hitting D emits D#, etc... Now with trsnspose set at -2, hitting C results in B flat being emitted and for instance hit a G at transpose -2 results in F being emitted... Simple isn't it? For MIDI all they do is add the transpose to the note number. Don't forget that the black keys are counted as well as the white ones.
Posted on Jul 13, 2011
Testimonial: "Very clearly explained, thank you so very very much, team, 'twas such a big help."
Amplifier Backroung hiss Noise Problem
Unfortunately, it's a design or manufacturing problem with all of these. If it's new enough return it and get a different make of amp.
Sep 04, 2016 | The Music
It wont play thru my amp only headphones and no demos or preset patterns
Re-initalize the machine. If that doesn't work, it's time to take it to the shop. However, replaceing it may be more cost effective.
Aug 19, 2015 | Alesis Sr 16 Stereo Drum Machine
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
I have a DM5 18 bit drum module. It is a while since it was last used and I can't find the mains adapter. I bought a new one and have it set at 9V. The unit switches on but it is very dim and I...
You CANNOT use one of those universal adapters, period. The DM5 Alesis takes an AC output adapter. You need 9 VAC at 830ma or more. AC output adapters are hard to find and you are not the first to try a universal and find that they don't work! Here is one of MANY sources on Ebay:
http://www.ebay.com/itm/NEW-9V-1A-AC-AC-POWER-SUPPLY-ADAPTER-fr-Alesis-DM5-Drum-/110700117691?pt=COMP_EN_Networking_Components&hash=item19c63dbebb
Sep 20, 2011 | Alesis Dm5 Drum Module 18 Bit
Hello, I connect my headphones to the Alesis DM6. As result, i can listen my drumming, while i'm playing. But, the sound is not always good. Sometimes I hear, only on one side the music, or it is...
you have a bad cable (wire) or a bad jack (where you plug in your earphones) plug your output into another device (guitar amp for example) and see if the problem persists. if it does then it is most likely internal problems with the output jack. If this is the case you will have to take the unit apart to find out where the problem is. if you're not comfortable doing this then you will have to take the unit to someone who is.
Mar 17, 2011 | Alesis DM6 Performance Electronic Drumset...
I need to know the correct way to play this drum machine through my amp.
If you have a direct out use that? You can also use the Headphone jack coming out. Make sure the volume on the DM is very low. And bring it up slowly.
Dec 27, 2010 | Alesis Sr 16 Stereo Drum Machine
Have the alesis dm6 there is no out put sound. monitor appears to be working. hooked to small amp or headphones. just fuzz. please help. little guys christmas present!!!
Two things:
Dec 25, 2010 | Alesis DM6 Electronic Drum Set
Where can I buy an LCD for my Alesis micron. I found someone who can do it but I need the LCD. There's this site that sells it but it's a little pricey and it has to be shipped. I live in the Philippines...
Many of the LCD's for these are rather special and as such are pricey. I would ask Alesis directely for parts source... You will likely have to live with whatever their recommended source charges.
Dec 04, 2010 | Alesis Micron Synth Keyboard
I just purchased an Alesis QS7 on eBay. Upon receiving
The unit needs to be repaired. Since it is a thermal problem, you can likely find the bad part with circuit cooler. See if the volume control affects the loudness of the howl... If it does, probably an op-amp in the preamp before the volume control is sick. If it doesn't affect it, then the output amps are suspect. Also check the power adapter.
Mar 03, 2010 | Alesis Music
Alesis MICRON Analog Modeling Synthesizer Logo
108 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
