Question about Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint hda3700g00bb water not heating
My dishwasher is not cleaning and the water is not getting hot
  • Hotpoint Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
e1
Posted on Sep 29, 2010
Have a Hotpoint dishwasher DWF33. Supplied with cold water supply from mains. My problem is that water is not heating during operation. Regards, Stephen.
Always supply hot water to the dishwasher...
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 10, 2011 | Hotpoint Dishwashers
Plumber has connected hot water supply to dish washer can that be a problem
For most dishwashers the hot water is the connection you want to have for the supply to the dishwasher...
I believe that it is also correct for this model also...
The dishwasher heating element will keep the water hot but is not powerfull enough to heat cold water effectively...
You will be just fine...
heatman101
Nov 19, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Glasses on top tray not cleaning properly
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Nov 04, 2010 | Hotpoint 24 in. HDA3740G Built-in...
I have tried everydishwasher detergent that there is and my dishes still dont come clean. my hot water is set very high, i was told to first run the hot water in the sink first. that does not sound...
Run hot water in the sink so that it is hot when it enters the washer. This is in case your heating element is not heating well enough. I realise this posting is not a solution but rather a possible clarification on previous advice.
Oct 09, 2010 | Hotpoint HDA2000G Built-in Dishwasher
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Friend got a hotpoint FDW 80 need to no is it hot water supply or cold?
Connect your dishwasher to the HOT supply line. The most common method is to connect to the hot water supply line in your kitchen. Before running the dishwasher, it is also a good idea to turn your hot water on to allow the water in the line to heat up. This will reduce the time is takes for the dishwasher to heat the water for the wash cycle and cut down on the cost of electricity.
Dec 07, 2009 | Washing Machines
Hotpoint dishwasher swd6o
all dishwashers don't heat the water themselves. the water supply should be tied into the hot water line under your kitchen sink.
Sep 18, 2009 | Dishwashers
Hotpoint dwt 10 dishwasher - the dishwasher tablet is not dissolving and remains in the bottom of the dishwasher after running a load therefore dishes arent cleaned!
I know it sounds strange, but many times when detergent dissolve, a failed heating element is to blame. The detergent needs that water to be hot to dissolve and activate the detergent.
Recommend you check the heating element for obvious damage/failure. When you run the full cycle, does the heating element get hot? If not, replacing it is not as hard as it appears. Post back here with further questions, OK?
If the heating element _is_ working, the other possibility is a failing wash pump motor, but depending on the age of your dishwasher, replacing
May 03, 2009 | Dishwashers
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Open Questions:
See all Hotpoint 23 in. BFI68 Built-in Dishwasher Questions
Hotpoint 23 in. BFI68 Built-in Dishwasher Logo
142 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
