Phone number of prc butuan - Computers & Internet
Have a BMW 2000 323I..replaced fuel pump ..Getting code P1250..any ideas ?
OBD code of: "P1250- PRC Solenoid Circuit Malfunction. Which malfunction of Fuel Pressure Regulator Control unit. PRC is located
by the fuel pump by the left side on the bottom rail under some plastic you will find it. PRC costs about $90.
Mar 15, 2015 | BMW Cars & Trucks
Bmw 2000 323I..code p1250.
Code P1250 is PRC malfunction, Which is for Fuel Pressure Regulator Control unit. I have answered this question already. PRC is on the Bottom fuel rail by the fuel pump by the left side under some plastic covers.
I have STC data card(hsdpa modem) TCT Mobile one touch XO8OS Made in PRC IMEI : 356237035950284 pls give me the NCK CODE thanks for helping
phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 08, 2012 | Cell Phones
P1250
The location of WHAT???
Diagnostic Test Code (DTC) P1250 is a manufacturer - specific code which has a general description of "Pressure Regulator Control (PRC) Solenoid Circuit Malfunction".
The PCM monitors input voltage at Pin number 44 when the ignition is turned on. DTC P1250 sets when less than .44 volts are present. The possible causes are:
> PRC Valve malfunction (open or shorted internally)
> Open or short circuit between the PRC valve and the PCM (control circuit)
> Open or short circuit in the solenoid ignition voltage supply circuit
> Failed PRC valve (stuck open)
> Malfunctioning PCM
Feb 17, 2012 | 2000 Mazda MPV
Got new battery for my Timex two weeks ago at Gaisano Mall. Now watch is dead. Repair technician at Gaisano said I need to take it to a Timex Center, because a circuit needs to be repaired. Is there any...
here's the address of service centers in Cebu TIMEX factory outlet Mactan Marina Mall . tel no. (032)3406638 and WATCH REPUBLIC SM Cebu Upper Ground Flr. tel no. (032)2336427. in Butuan timex only has drop off center at GAISANO BUTUAN. I hope i had helped you.
Jul 17, 2011 | Timex Expedition 84601 Wristwatch
1.death claims benefit 2. provident claims the availment of this benefits it necessary to claims with in the region where the place remitted? my brother reside in Lucena City then their family leave now...
FixYa does not have the expertise to advise you on this matter.
You need to go to the Government Social Security department for this advice.
Jun 09, 2011 | Cell Phones
My prc 200 is not working maybe its the battery?
These watches are "automatic" which means that the are self winding.
They will run for 1 -2 days before stopping. Shake the watchgently from side to side for a few minutes and it should start again.
(These watches need to be constantly used to keep them working).
Dec 12, 2010 | Tissot PRC 200 T17.1.586.32 Watch
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
