Question about Maytag MSD2756G Side by Side Refrigerator
Panel on front of door
The panel on the front of the refrigerator that you use to engage to dispense your ice or water; the contact points are peeling off! What can I do, hopfully I will not have to replace the entire unit that the panel resides in!
  • Maytag Master
  • 909 Answers
Use small amounts of super glue in necessary areas of keypad.
Posted on Jul 23, 2007
Maytag mfi2568aes control panel
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
May 16, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Puddle in front of TFX24CRS
If there is ice on the floor of the freezer, you have a blocked defrost drain. If no ice there, you are getting water from the water / ice dispenser, possibly down the back side of the door panel.
Seal the seams around the water catching recess at your dispenser with a bit of clear silicone. (corners and along the front edge seam with the front door panel.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser on our GE Adora refridgerator (DSS25KGRA) stopped dispensing water. The internal icemaker still makes ice and the door unit dispenses ice both cubed and crushed. Could the water line be...
Most of the time it is the half of the dual water control valve on rear of refrigerator. The part number Click Here=> WR57X10032 Usually the coil on that side will go bad before buttons or controls. You can test that side by setting a test meter on AC voltage and you should read 120 volts while someone presses dispense water on front. There are two sides one plugs into icemaker side and other water dispenser. When replaced they both come as a kit. If you would like you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
83 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
