Question about GE 74801 Clock Radio
Manual for sentry clock CL933
How to set clock,date and time
How do i set time on sentry radio controlled alarm clock
I lost the directions to set my Sentry Radio Controlled clock.......
Can anyone help me?
Nov 18, 2012 | Audio Players & Recorders
How do i set the date on my nixon sentry
The notch has two positions. when you pull it out completely that is the time adjustment. Now when you pull it just slightly that will be the date setting. Turning it clockwise will change the day and counter clock wise changes the date number. Hope that helps.
I got my watch from a third party w/ out manual cause it was cheaper. Took me awhile to figure out.
Nov 13, 2010 | Nixon Sentry Watch
How do I set my Sentry talking clock?
Many Sentry product manuals can be down loaded from the following URL
http://www.sentryindustries.com/support/manuals.asp
The instructions for Sentry CR104 is located at the following URL
http://www.sentryindustries.com/pdf/instructions/CR104_instructions.pdf
This may be unrelated to your problem, but
I have noticed sometimes the instructions tell you to use the ADJUST key.
If that does not work try the SET key sometimes it will work instead of the ADJUST key.
Mar 12, 2010 | Sentry CR104 Clock Radio
How can I set the timezone on my Sentry self-setting atomic clock?
Jan 09, 2010 | Sentry CR104 Clock Radio
Clock slow
Set the date and time To set the date and time displayed on the BlackBerry smartphone, complete the following steps:
  1. In the Clock application, press the Menu key.
  2. Click Options.
  3. Click Set Time.
  4. Set the date and time.
  5. Press the Menu key.
  6. Click Save.
Retrieve the date and time from the wireless network To retrieve the current date and time from the wireless network, complete the following steps:
  2. Click Options.
  3. Click Set Time.
  4. Set the time zone in the Time Zone field.
  5. Perform one of the following actions:
    • To retrieve the date and time from the wireless network that your BlackBerry smartphone is connected to, change the Date/Time Source field to Network.
    • To retrieve the date and time from the BlackBerry® Infrastructure, change the Date/Time Source field to BlackBerry.
  6. Press the Menu key.
  7. Click Update Time.
  8. Press the Menu key.
  9. Click Save.
Note: To set the time manually, change the Date/Time Source field to Off.
Sep 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Nov 02, 2008 | Canon MP-25DV Calculator
Sentry CR-106: setting the projector's time.
I found my manual!
To set month, press the "set" button 2 times then press "mode" to sequence month
To set date, press the "set" button 3 times then press "mode" to sequence date
To set hour, press the "set" 4 button times then press "mode" to sequence hour. (24 hour clock toggles with 12 hour clock)
To set minutes, press the "set" button 5 times then press "mode" to sequence minutes.
I hope this helps!
Oct 07, 2008 | Audio Players & Recorders
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
Operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
May 20, 2007 | Timex T311T Clock Radio
GE 74801 Clock Radio Logo
113 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
